charger selection
DesertGate
Registered Users Posts: 1 ✭
Hi, I have a remote site that I run wifi gear on. it is AC powered, however has frequent outages. I purchased 3000 Watt 24 Volt Rack Mount Inverter TO 120 Volt AC - 2U and setup 8 12V 155Ah batteries in series and parallel to use as backup when AC fails. I am needed a recommendation for a product that will automatically charge the batteries as needed when the ac gets restored.
I use a Genius brand smart charger to keep my generator starter battery full. Pick a model with enough output to charge your entire bank in a day or so.But how much wi-fi gear do you have, that needs a 3kw inverter to power it ? Oversize an inverter too much, and it's self-consumption can exceed the load requirements.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 626 Discussion Forums/Café
