xantrex freedom xc series inverter charger
bobiowa
Registered Users Posts: 3 ✭
I cannot get my inverter to come on. It was working fine earlier. I did have my windshield replaced this afternoon in my sprinter and there are some electronics in it that need to be calibrated .....but I did not think the two items were related. The controller is working and the batteries have juice...any ideas?
Do the standard cold reboot, turn off switch, disconnect battery, wait 5 minutes, reconnect battery, turn on hopefully it will restore itself. This often solves problems, but not always, good luck. What inverter do you have?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
thanks
worked great thanks
