Invisible dog fence on solar power
jodilw1020
Registered Users Posts: 1 ✭
Hello,
I’ve been reaching out to several invisible dog fence companies on how to run the fence on my 40 acre off grid property. Is there a simple way to do this?
I run my horse fencing off a solar unit but the canine fencing companies don’t work off 12 volt batteries.
jodilw1020 said:Hello,
Looks like at least the Pet Safe run on 12 volts/2 amps, Not sure of the 'real draw' but about 25 watts available 24/7 would require about 50 amps That's a pretty good sized load. You might do that with a 2 golf cart battery system and a couple hundred watts of array. It's quite a bit more demand than a Hot wire, I think my 120 version uses 6 watts AC I have no idea what a solar hot wire uses, but I'm sure less.
https://www.amazon.com/Accessory-USA-Adapter-Petsafe-Wireless/dp/B00Q89RKEQ
- 218 Forum & Website
- 646 Solar Water Pumping
- 813 Wind Power Generation
- 598 Discussion Forums/Café
- 72 Construction
