About multiple uses of VFD drive of solar pump
kcbibek310
Registered Users Posts: 21 ✭✭
I am thinking of using VFD of a solar pump for other purposes when the pump is not working. I am thinking of using it in a thresher. Is this possible to do so with the same pump controller/inverter? If possible then how can we do so and what is the perfect controller for such purposes?
VFD's are made for specific motors. If your thresher has the same motor as the pump (doubtful) it would work.
Long ago on an industrial drive application I needed to do a proof of concept system where I wanted to drive two different horsepower motors from the same drive. This was an industrial VF drive with a removable HIM module. The drive had no problem driving a much smaller motor but the settings had to be reprogramed for the smaller motor. The solution was get a spare HIM module and program it for the smaller motor. When the motors got swapped, we would swap the HIM.
- 626 Discussion Forums/Café
