Help finding one replacement solar panel
2»
  • WhittakerJWhittakerJ Posts: 66Solar Expert ✭✭
    > @Photowhit said:
    > So I just got back, and looks like this is what you were originally looking for "TSM-PA14-270W" but the label is 275 watt it should work fine. It was the PC's that may not have the correct labels for your inspector.
    Yea this is the same panel just 5w difference. So it will work fine, yea? Also given the age, 3 years or so, I bet the wattage will be about the same.
2»
