2"well point pump
just startingjust starting Posts: 221Registered Users ✭✭
Does anyone know of a 1 panel 2"bore submersible pump that can do 1-3 gmp with no controller or built in mppt?
200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024  - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher  Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
  • AnawaAnawa Posts: 207Solar Expert ✭✭
    Well point? Are you dewatering an excavation or something similar?
    What is the static water level? Can you use a suction pump?
    Paul
    in Georgia
    System 1: PV- 410w Evergreen, Mppt- Blue Sky Solar Boost, Batt - 225ah Deka AGM, 12v led house lighting,
    System 2: PV- 215w Kyocera, PWM - Morningstar PS30, Batt- 225ah Deka GC's, 12v led house lighting, Dankoff 12v water pump,
    System 3: PV- 1.5kw Kyocera, Grundfos 11 SQF well pump, 3000 gal above ground water storage, dom water & irrigation,
    System 4: PV- 6.1kw Kyocera, Mppt- Outback FM80-2ea, Inverter- Outback FX3648-2ea, Batt- 804ah GB traction, Grundfos BMQE booster pump 240v, Mitsibushi mini-splits 240v, 18k and 15k
  • just startingjust starting Posts: 221Registered Users ✭✭
    I live in mine contry on a claim. My neighbor has a drift with a well point to drain water from under his working need a better way running a gen is not cost effective just to start work.its a spring just has to wait on water, works 2-6 in the mine most days. It olny needs to pump out while the sun is up
  • jonrjonr Posts: 1,085Solar Expert ✭✭✭✭
    Still not clear what depth you need to pump from.   An option for greater depths is a 2" packer ejector with a surface jet pump.  But the direct solar pumps I'm aware of are submersibles more than 2" in size.
    Max is 150'
