mixing battery's and modified inverters
mike74820
Registered Users Posts: 44 ✭✭
i know mixing them is really bad thing too do, but i want to go to 24 volts, how long will mixing 2 golf cart 235hr battery's and one deep 105ah marine battery last? and also how well does led tv's and led lights run off a modified sine wave inverter ? thanks in advance for your answers
mike74820 said:i know mixing them is really a thing too do,mike74820 said:and also how well does led tv's and led lights run off a modified inverter ?
i fixed the post i know they arent the best thing too.
Usually, the Marine Battery is going to be the "weak link" in the system.
As long as you treat the string as a 24 volt @ 105 AH battery bank and don't deep cycle it very much--It could work OK.
Secondary issues could arrise... A possible problem would be the older(?) deep cycle batteries will have higher self discharge current--And when you try to bring the bank back to >90% state of charge, you may end up with the marine battery at >90% and the deep cycle at <80% SOC--And when you equalize, the Marine battery may use "lots" of extra water and possibly even overheat.
For experimentation--It should work. For a run and forget system--I would highly recommend avoid this type of operation.
The MSW vs PSW/TSW inverter issue should be pretty much unrelated to the battery bank question. Instead, it is the AC loads that will be affected by the MSW/PSW inverter question.
Induction motors do not like MSW (tend to run hot). Some electronics will run hot or even fail (minutes/hours/days--who knows). It is the old 80/20 rule. Probably 80% of the loads will run OK. Another 10% will fail, and the last 10% could have issues (run hot, noisy, or fail eventually).
sounds like it's better just to wait until next year to go 24 volts and do it right thanks for all your help
modified sine is pretty well known for burning out advanced electronics.
- 626 Discussion Forums/Café
