Battery issues
The509
Registered Users Posts: 26 ✭✭
First post so don't slam me
I bought 8 Trojan L16 last year before the fires. They sat for 6 months before I hooked them up. Strung at 24 volts Xantrex MPPT and 3 X 250 watt panels. I live at around 3400 feet in WA and have great sun. Each day they seem fully charged but when I wake I'm showing output of like 23 volts. The only load I have on them is a couple cigerette lighter outlets charging iPhones.
Is that normal?
Is that normal?
In general, flooded cell lead acid deep cycle batteries need to be recharged (~24 hours on a standard AC battery charger) at least once a month minimum.
If you leave them sit for ~6 months without charging, the batteries go below ~75% state of charge (after one month) and start sulfating faster and faster. After 6 months of no charging--There is a good chance that these batteries have very little of the original capacity (sulfating is when the "fluffy lead-sulfate" turns into a hard/black crystal that no longer participates in the charging/discharging chemistry--And also "insulates" the plate surface).
There are "de-sulfators" that people sell who claim can recover sulfated batteries--But there is great controversy about whether they work or not (this is the only discussion here that "routinely" results in locked threads).
Which Trojans do you have? If they are AGM--Then setting for 6 months should not have sulfated them (AGM batteries have lower self discharge). Your next issue is you may simply not have enough charging current. For example:- 8 batteries x 420 AH * 7.3 volts charging * 1/0.77 panel+controller deratings * 0.02 rate of charge = 637 Watt array Float Service
- 8 batteries x 420 AH * 7.3 volts charging * 1/0.77 panel+controller deratings * 0.05 rate of charge = 1,593 Watt array minimum
- 8 batteries x 420 AH * 7.3 volts charging * 1/0.77 panel+controller deratings * 0.10 rate of charge = 3,185 Watt array nominal
- 8 batteries x 420 AH * 7.3 volts charging * 1/0.77 panel+controller deratings * 0.13 rate of charge = 4,141 Watt array "cost effective maximum"
If you start cycling the battery bank, you really need more solar panels to do it justice.
Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset - 8 batteries x 420 AH * 7.3 volts charging * 1/0.77 panel+controller deratings * 0.02 rate of charge = 637 Watt array Float Service
Welcome to the forum.The509 said:Each day they seem fully charged butThe509 said:I bought 8 Trojan L16 last year before the fires.
<snip>
The only load I have on them is a couple cigerette lighter outlets charging iPhones.The509 said:Xantrex MPPT and 3 X 250 watt panels.
VtMaps makes a good point, many 250watt panels have too low VMP to properly charge 24 volt battery banks.
If they are flooded batteries, equalizing may help recover some of the lost capacity.
What settings are you using with your charge controller?
@BB The sitting idle was beyond my control due to the wildfires here last year..I was thinking about ordering 2 more panels this week and would like to be up to 8 total st sum point. The sad thing is we really don't use that much power. Id be surprised if we used 2 KWHs a day during the summer when the kids are home all day.. L16RE-B
@VTmaps, im going off output and input on my Xantrex. Im still learning and figured that if my batteries are on float with no real load that they are for the most part charged..My panels are wired in Parallel..
http://www.solar-electric.com/solar-panels-mounts-kits-accessories/solarpanels/kyocera-solar-panels/kyocera-ku265-6mca-265-watt-multicrystal-solar-panel.html
I really appreciate the help. Im trying to take this all in
Sorry about the fires--It was bad last year.
Your best bet would be to design the system to the amount of power you want to use (summer/winter) and go from there.
Do you have utility power, or is this a pure off grid system? 1-2kWH per day is a nice job of conserving power. Does not sound like you are running a refrigerator or large well pump, etc.
Im off grid, fridge is the huge Crystal cold propane, stove and water heater are propane as well...I could run power for about 5gs. But my wife and I like the whole no electric bill thing..Coming from Texas were we paid 300-400 a month to buying 500 gallons of propane each year is fantastic.
Well is in, and yes, its electric, but when i built, i put in 2, 500 gallon water tanks.. So i just turn on the Briggs and fill them up, once a month normally.
VTmaps said i should of wired my panels in series versus parallel. Do you know why? Should I go up and change them now?
The509 said:My panels are wired in Parallel..
Your panel's Vmp is 31 volts, but in the hot sun it will be several volts lower. Meanwhile your battery needs 29-31 volts. An MPPT controller should have its input voltage at least 12 volts higher than the battery charging voltage.
So i just ran them in series. How many more panels am i looking at? My goal thru all this is really for the kids to come home and run the TV and Xbox for a couple hours after the sun is down..Nothing more..Is there a certain type of charger i should get?
He probably would tell you to run 2 panels in series into the controller. You need an even amount of 2 panels per string. The strings are in parallel.
At a minimum you need one more panel. 2 x 2. Your charger is fine. Measure SG and do an EQ . List your set-points here!
You really need to do somethings soon as the morning voltage of the battery should not be below 24V on most days. My systems are at 24.5V and usually 25V in the morning."we go where power lines don't" Sierra Nevada mountain area
The509 said:So i just ran them in series.
Also, although MPPT controllers need headroom, too much makes them inefficient (runs hot, shorter lifespan, less capacity to handle power). In other words, 114.9 volts input may work, but it is not optimal.
Panels such as yours (and mine) with a Vmp of 30-31 should be configured with a string length of 2 (Vmp = 60-62) when used in a 24 volt system. In other words, you need an even number of panels. You should also have a combiner box with circuit breakers.
right now, nights are close to 30.Should I go run 2 in series, and one pos to pos? until i get my new panels in?
Fill in the gaps here please... how far away is the cabin? how long a drive, etc.. When will the other panels arrive?
YOU NEED TO , ASAP, GET A BETTER CONFIGURATION OF THOSE PANELS DONE, LIKE TOMORROW, IF ABLE, TIME IS OF THE ESSENCE FOR YOU TO SAVE YOUR BATTERY INVESTMENT!
3 panels will be the best for the interim, then change it to 2s x 2p or 2s x 3p or .... S = series p = parallel...
hope this helps
im in the middle of nowhere..The closest big city is Omak Wa..population 5000.. I ordered 3 more panels but it will be a week before they get here..I unhooked the 3rd panel and im running the other 2 in series. Is there a way to tie the 3rd panel in without risking anything?
as VTmaps said "Hold on there... those panels have a Voc of 38.3 volts. If you put 3 in series the string Voc will be 114.9 volts. That's probably OK, depending on where you live. If you are in a very cold climate, the Voc could rise high enough to fry your controller."
Yes, you could run 3 in series, but you have to confirm that is within the max limits of your controller which you have not fully identified the model you are using to us.
hth
He said an mppt-60-150 and so he is fine for now. Just not a good way to run this combination. With winter an all still, I would run these all in parallel to get more power and then rewire before it gets warm or with new panels.
Probably get the generator going and give a nice long 4 hour absorb and then an EQ and measure SG"we go where power lines don't" Sierra Nevada mountain area
So, put them back the way they were until i have 6 panels, then run 3 sets of 2 in series, and charge for 4 hours today..So, don't flame me for this, but i switched over to 24 volts like a month ago. i don't have a 24 volt charger i have a Pro Series 30/60 12/6 volt, but i can run down to sears and grab one today..When you say charger, are we talking something like this? The associated brand? http://www.sears.com/search=24 volt battery charger The charger was gonna a be a question for a later day
Are you planning to buy an inverter? If so, buy an inverter/charger. If you buy just a 24 volt battery charger, make sure it can put out at least 60 amps. I don't think you will find anything at sears that can do that.
i have a 24volt AIMS Pure Sine which i really like..
specs on the in stock chargerAssociated Equipment 6006 6/12/24V 70/65/30 Amp Charge 280 Amp Cranking Assist Charger with Wheels
Not good enough>?
Anything will do for now! Just get them charging and measure/list the SG"we go where power lines don't" Sierra Nevada mountain area
batteries 1-8
1250 1225 1225
1225 1230 1225
1250 1225 1230
1215 1210 1175
1150 1125 1100
1250 1225 1200
1200 1150 1150
1225 1225 1220
And so this data is after what kind of charging?"we go where power lines don't" Sierra Nevada mountain area
Normal day, no real load, CC said i put 1.98 KWH into the bank..I unhooked the CC from the batteries for about 30 mins before i did the test which was 15 mins before i posted.. The CC said Float pretty much all day, .Sorry i cant be more specific. What info are you wanting i might be leaving stuff out
Well, you can see from your chart that you have both of the basic problems flooded batteries can have when not charged properly.
You have large differences between the readings and at least one battery that is far different than the rest.
The info needed is what is the bulk absorb set to? (it should be around 29.5V) What is the absorb time. (it should be 3+ hours) And what is the EQ voltage? You should verify the numbers with your trojan manual and verify there is a temp sensor on the mppt.
If I were you I would do a 1 hour EQ @ 31V after you go to float. Then check the lower reading cells and see if they come up.
Then do more 1 hr EQ's. Good Luck!
Look at your battery wiring and maybe take a picture of it."we go where power lines don't" Sierra Nevada mountain area
i used this chart off the net i can take a pic if you want but thats how its hooked up..bat 1 is top left 2 is below and so forth if your looking to compare the numbers i posted earlier..
How about all the set-points and charging data? A pix is nice but you really need to address the earlier part about loading.
A couple of cell phones is not going to pull the bank down to 23V, even with the low SG readings. So that is one ? thing.
After you get the batteries closer in SG, I would get a 1500 watt electric heater and start putting loads on the bank. More later after you
list your set-points please.
Fires always suck! we just have to live with them and be safe."we go where power lines don't" Sierra Nevada mountain area
ill get the points..after hooking up the panels in series, i haven't dipped below 24volts when i wake up..And that's just the 2 panels as i unhooked the 3rd after you guys told me it wasn't a good idea..i have 3 more coming in
Eq is 32
Float is 27
Bulk and Absorb are both 28.8
and absorb time is 180 mins
Do you actually get 3 hours of "absorb" in a day? (i.e., battery bus voltage >28.8 volts for 3 hours per most days)?
And according to this--The 77F daily charging voltage should be around 29.6 volts (if I got your correct battery type):
http://www.trojanbattery.com/pdf/datasheets/L16HAC_Trojan_Data_Sheets.pdf
32 is a little high but should not hurt with the SG's you have. Your Absorb is too low. It should be at the high end of Trojans 2.35 to 2.45v per cell. I would set it to 29.4V . If there is a temp sensor it will be higher this time of year.
Did you do an EQ ?
Hi Bill ! he said it is in float all the time. And whatever the trojan type battery Bill's 29.6v absorb will not hurt.
The load test is needed to find out more. He probably does not get the full absorb as the xw charger will go to float at 2% of the capacity setting. This is a good point Bill.
509, I would set your battery capacity for now down at 200 AH. This will keep the charger at absorb longer."we go where power lines don't" Sierra Nevada mountain area
Doing EQ now at 31..Will change the absorb when its done.. What should i do with the 3rd panel while i wait for the other 3?
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
