Using DC clamp meter
just starting
Registered Users Posts: 235 ✭✭✭
So I have six strings of agm batteries today I put a 32 amp load on the bank and checked all strings in the center after a min they all were pulling 5.8 to 6 amps so is it balanced or should I test during bulk with inverter off
200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
That seems like it would be an acceptable range for non-contact meter errors. Did you record which strings pulled which power ?
It would not hurt to once in a while check while doing heavy charging/equalizing too... You are looking for differences that may indicate future problems (weak cell, bad connections, over heated battery, etc.).
But it does sound like your wiring and battery bank is fine.
Checked while charging its the same across the bank with in one amp200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
While you're at it, pick up a handheld IR pointer temp meter at nearly any home improvement store. Some have laser pointers built-in.
Even though your current seems to be balanced, with the handheld pointer, you can identify if anything is starting to get hotter than the rest of the system early, like loose connectors, poor crimps, even individual cells in the batteries themselves.
Spotting something getting warmer than normal early on can easily justify getting one of these tools.
Cool thanks200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
Keep looking at this. Really nice for a quick thermal scan:
http://www.amazon.com/Seek-Compact-Thermal-Imager-Android/dp/B00NYWAHHM/ref=sr_1_3?ie=UTF8&qid=1453755858&sr=8-3&keywords=ir+camera
The Apple version is even quite a bit less (surprise!).
- 626 Discussion Forums/Café
