Best way to set up equipment in room, on other side of house from electrical panel.
solar95119
Registered Users Posts: 3
I'm planning on installing a grid tied system with battery backup and would like to have all the solar equipment(inverter, battery, etc) on the other side of the house (about 100') from the electrical panel (outside). What's the best way to go about this? I'm assuming this involves running thick gauge wires in the ground...or is it possible to run the wires in the attic crawl space? Thanks in advance.
How large of solar array, battery bank (AH and Voltage), and branch circuit from the AC main panel (120/240 VAC and what amps?) are you aiming for with your system?
Are you doing this to save money, going "green", or preparing for possible power failures?
There is nothing really special about the cabling from the AC main panel to the solar hybrid inverter... A bigger question is "what will you be wiring" for backup power/etc... Normally, one would put the AC hybrid inverter near the main panel so you can wire up the "protected circuits" to be powered by either AC Mains or Hybrid inverter output. However, you can run AC panel to hybrid inverter (AC 1 input)... And from the AC output (hybrid inverter) back to near the main panel for powering protected circuits...
Doing it in the attic vs underground--Are you going to have a licensed electrician do the wiring/pull the permits? There is no big reason to choose attic vs underground. Just which gives you the cheapest (and cleanest) installation costs.
The wires will not be 12ga "romex" style, for a 100' run, they will be larger and may need to be in conduit. Don't know if they can share the same conduit, or if you need 2.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thanks Mike & BB. I'm planning on using about a 5kw solar array and 8 AGM L16 or 8 Rolls S550 flooded L16 batteries.
And yes all of the above to save money, going green and power failures. Also could you tell me about the process with interacting with the utility company, PG&E in my case. Would i still be able to sell back power if i have a grid tied w/ battery backup system?
And yes I'll have a licensed electrician help with wiring and permits.
Yes BB, I'm assuming I'll need go thicker than the 12ga romex style.
Thanks again guys.
solar95119 wrote: »...... I'm planning on using about a 5kw solar array and 8 AGM L16 or 8 Rolls S550 flooded L16 batteries.
And yes all of the above to save money, going green and power failures....
solar95119 wrote: »I'm planning on installing a grid tied system with battery backup and would like to have all the solar equipment(inverter, battery, etc) on the other side of the house (about 100') from the electrical panel (outside). What's the best way to go about this? I'm assuming this involves running thick gauge wires in the ground...or is it possible to run the wires in the attic crawl space? Thanks in advance.
You could run the conductors between the inverter and the electrical panel either above ground or below ground, either in conduit, or in a cable/conductors approved for the location. It sounds like the house is already there so Im guessing going underground isnt a good option. Type SE or SE-R would be a good inexpensive option, looks like you want around 6 or 4 gauge. Just beware of cable assemblies with PV as PV runs are often upsized for voltage drop and that triggers a NEC required increase in the equipment grounding conductor size. Sometimes you would have to get a cable with an extra conductor and abandon the bare EGC. Just make sure your electrician is on top of it!
I agree with Mike about the batteries. Get a $599 home depot generator instead, or if you want automatcia transfer, get a small propane gen with automatic transfer switch. -
Got it, thanks Mike and Ethan for the feedback.
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
