Outback GVFX vs FXR inverters
verdigo
Solar Expert Posts: 428 ✭✭
I just noticed the GVFX inverters are no longer for sale but have been replaced with FXR inverters. They look identical. I bought my GVFX 3648 with the assumption that I could later get another one to stack for split phase operation. Does anyone know if this is just a change in designation or does the FXR inverter have significant firmware changes?
They seem to still be on their web site.I just noticed the GVFX inverters are no longer for sale but have been replaced with FXR inverters. They look identical. I bought my GVFX 3648 with the assumption that I could later get another one to stack for split phase operation. Does anyone know if this is just a change in designation or does the FXR inverter have significant firmware changes?
FXR- GridZero Technology
- Advanced Battery Charging
- Seven Programmable Operating Modes
- Remote Monitoring AND Control with OPTICS RE via MATE 3
- True Grid/Hybrid Performance
GVFX
http://www.outbackpower.com/outback-...id-interactive
FXR
http://www.outbackpower.com/outback-...dhybrid-series -
I wonder if a GVFX can be upgraded and if it would be worth it. NAWS doesn't seem to be selling the G inverters anymore. I'll have to do some reading when I get some time.
I did a little bit or reading. Wish the FXR came out a couple of years earlier. The FXR has a much wider frequency acceptance for dirty cheap generators. The "Grid Zero" function of preference for renewable energy sources would great as well. I did post the question on the Outback forum if a GVFX can be converted to an FXR inverter. I would need a Mate three for sure, and hopefully the logic board?
OK, here is what David from NAWS says:The GVFX and FXR are not compatible at all. They can’t be stacked together.
This is also the case with the rest of the Outback inverter line.
They have a whole new board set.
Outback is saying they are currently not discontinuing the GVFX inverters. Not as of right now….
I will say that I have a couple GVFX inverters I’m trying to get rid of if someone needs a deal.
http://www.solar-electric.com/products-onsale/
I might be willing to go lower.
The FXR inverter will require the mate3.
Yeah right.
