Panel Angles
2»
  • yrtrnc
    yrtrnc Solar Expert Posts: 54 ✭✭
    Re: Panel Angles
    What do you think of this site guys? http://energyworksus.com/solar_installation_position.html
    Re: Panel Angles
    this is my general speak without rereading the thread.
    that site is ok as it can reveal an angle at a particular time of day/year and at best would be a starting point. the best angle is determined on what you are after. if you are selling to the grid then you may want to maximize the summer production. if you want a year round average then the latitude plus 15 degrees is good to use. finally some need to optimize winter production.
    the middle one is at latitude +15 because the latitude is only representing the highest point in the sky the sun reaches in the day and most times the sun sits lower to the horizon before and after solar noon. the +15 degrees semi-compensates for the lower to the sky angles without overly compensating due to side to side excursions. remember that solar noon +/-1 hour represents about 15 degrees to the side of solar noon so that 1 hr before and 1hr after solar noon the pv will only be off by 15 degrees and a tad more than 15 degrees at solar noon itself giving a bit more power from the off solar noon times.
    sometimes the best overall pv angle will not be good to use if there is snow involved as a tad more angle can cause the snow to leave the pv surface allowing for power production whereas the ideal theoretical angle may be non-productive due to that snow cover. this angle often corresponds well with the better winter angle for those in northerly latitudes, but if in a more southerly area with high altitudes the angle may need to be off the better collection angles to better rid snow by.
  • inetdog
    Re: Panel Angles
    niel wrote: »
    ...the middle one is at latitude +15 because the latitude is only representing the highest point in the sky the sun reaches in the day and most times the sun sits lower to the horizon before and after solar noon. the +15 degrees semi-compensates for the lower to the sky angles without overly compensating due to side to side excursions. remember that solar noon +/-1 hour represents about 15 degrees to the side of solar noon so that 1 hr before and 1hr after solar noon the pv will only be off by 15 degrees and a tad more than 15 degrees at solar noon itself giving a bit more power from the off solar noon times.
    This also means that if you have a seriously East or West of South facing angle for the panels, the sun will be lower in the sky during their peak production too, especially in winter, so adding even more degrees can be better.
    SMA SB 3000, old BP panels.
  • NorthGuy
    Re: Panel Angles
    inetdog wrote: »
    Not necessarily. If you're facing East then most of the time the Sun will be to the side of the panel (mid-day) or behind them (in the evening).
    By making them more vertical, you get weak morning sun, but cut off most of the strong mid-day sun and all of the evening sun.
    If, however, you make them more horizontal, you will lose some of the morning sun, but you'll get much more of the mid-day sun, and also some of the evening sun.
  • SkiDoo55
    SkiDoo55 Solar Expert Posts: 414 ✭✭✭
    Re: Panel Angles
    That's correct for my Grid tied which wants summer peak, my arrays face 156° True(being added this summer) and the current operating array faces 246° True and the optium tilt is 22° at those azimuth angles. Mine are set at 18.5° just because that is the roof pitch and I loose very little for the slight difference. Would probably need some more tilt for an off grid installation for winter production
    GT3.8 w/4600W Trina 230W, TX5000 w/5000W ET-250W, XW4024 w/1500W ET-250W, 4 L16, 5500W Gen. (never had to use) Yet!!
    Re: Panel Angles
    know that the sun sits lower to the horizon in the east or west directions and that 22 degree pitch is probably not optimal for gt collection geared with summer peaks in mind in those directions. it won't ever be a total loss as that flatter area will respond better to the sun as it swings higher in the sky towards the south. you will always reap some solar, but it can be argued to death what the best angle is.
  • SkiDoo55
    Re: Panel Angles
    Optimum angle per California Initiative per there calculator for those azimuth is @ 21 deg. And optimal for due south also. I loose about 200 kWh per year being at 18 deg. According to CSI Incentive calculator the second (new) system is forecast to produce at least 7,179 kWh for the year. Currently producing system was predicted to produce 6,329 kWh and actually produced 6,685 kWh last year. Averaging about 28 kWh per day right now until the 100's F come in. First system has produced 2,523 kWh so far this year. In Jan did 309 kWh and in Apr 744 kWh. Will put in some numbers in PV Watts and see what the difference is.
    Figured the CSI Calculator would be pretty close or on the conservative side as the state used that for paying out money on there rebates. It uses PV Watts numbers in it's calculations. They give the design factor for new system a 95.480% of optimum for geographic location.
    Ran some number on PV WattsV2
    5.0 kW DC, 18.5° tilt, 156° Az, .77% derate = 6727 kWh annual
    5.0 kW DC, 39.6° tilt, 156° Az, .77% derate = 6757 kWh annual
    5.0 kW DC, 39.6° tilt, 180° Az, .77% derate = 6886 kWh annual
    Looks like only about a 2.4% loss form PV Watts Defaults and installed angles of system for the year. on my 4.6 kW DC system I am actually producing better than what is forcast for the new system. it is producing 22% better than what PV Watts comes up with for it at it's currentl numbers.
    In both winter and summer I have some neighbor tree's shading. Morning shade on the south/east and late evening shade on the west, also, some afternoon power-lines. Rought calculation I am loosing 1.5 - 2.0 kW per day.
  • coominya
    coominya Registered Users Posts: 8 ✭✭
    Re: Panel Angles
    Thomas, I'll try to explain MPPT controllers for you. (For simplicity in this explanation, we'll ignore all system losses etc.)
    Lets assume you have a solar panel capable of putting out 5 amps @ 36 volts at it's most efficient point electrically. Now you take that panel and connect it directly to your 12 volt battery (or through a PWM controller). The battery instantly loads down the panels to say 12.7 volts, but the amperage stays at 5 amps. What the panel is CAPABLE of putting out is 5X36=180 watts. But you have reduced that to 12.7X5=63.5 watts. You've just installed a system that's throwing away over 115 watts!
    Now, replace your PWM controller with a MPPT controller and everything changes.
    Your MPPT controller, electronically finds that the Max Power Point of your panels is 36 volts, so it only loads the panels to that voltage. Thus what's going into your MPPT controller, is 36VX5A=180 watts. The MPPT controller, using it's electronics takes that 180 watts, and like an AC transformer, drops the voltage down to the battery voltage of 12.7, and since it has 180 watts to work with, it increases the current going to the battery to over 14 amps, even though the panels are only putting out 5 amps! This is the beauty of the MPPT controller and what it does.
    Hope this helps you grasp the understanding. (Keep in mind that this is a very simplified description, ignoring all system losses etc for simplicity)
    Thanks Wayne, a simple concept that you have managed to explain in a simple understandable manner. You should be drafting instruction manuals for a living.
  • fauss
    fauss Registered Users Posts: 26 ✭✭
    My house faces almost east and west so are there any threads or pictures about trying to tip your panels south on an eastern facing roof. I get a bunch of morning sun and not alot of late sun. Also I live in the Pacific Northwest and I know I won't have perfect sun conditions.
  • alcatel99
    alcatel99 Registered Users Posts: 31 ✭✭
    still confused on tilt angle   i live at Latitude 34.889 " in North East Arizona  i am building my own ground mount for the solar panels i will not be able to change the rotation of mount east to west but will be able to change the vertical angle i looked up the settings in Solar Electric Hand book and his average seems to be around 50 " for year round  in Arizona is any one else in this part of AZ who can help out or recommend i have read through this thread but still unsure of angle to use.
    Thanks for any help
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,046 ✭✭✭✭✭
    Add the "Solar Tilt" app to your phone. Very versatile app  An extra bonus to this app is the tilt gauge that turns your phone into an angle finder
    If you are using this website:
    Note that it uses the angle measurement from vertical. So 50 degrees from vertical is equivalent to 40 degrees from horizontal (90-50=40 degrees).
    If you are at 35 degrees latitude, that is pretty close to the typical latitude=best overall yearly harvest (i.e., 90-35l at=45 degrees from vertical). I would not expect a lot of change in harvest with a 5 degree "change" (see below for PV Watts test).
    If you use something like PV Watts (and most other programs) seem to pretty much use tilt from horizontal measurements.
    PV Watts does not give a suggested best summer (typically +15 degrees flatter), yearly best harvest (typically = Latitude), or winter (typically +15 more tilt).
    Using PV Watts for Slow Low AZ, playing with the numbers for a fixed south facing array):
    https://pvwatts.nrel.gov/pvwatts.php
    20 degrees from horizontal (35-15=20): 6.26 hours of sun yearly average (daily average over one year)
    35 degrees from horizontal (35 = Latitude): 6.39 hours of sun yearly average
    45 degrees from horizontal (35+10 degrees): 6.28 hours of sun yearly average
    50 degrees from horizontal (35+15=50 summer): 6.17 hours of sun yearly average
    Of course, the above does not include the best/worst of summer/winter month harvest--Just total yearly average (may be best for GT solar systems; but for an off grid system, you may want more summer or winter harvest based on A/C and Refrigeration/irrigation/etc. loads/needs).
    So, from a "rule of thumb" design, the +/- and zero 15 to latitude seems to be pretty consistent with PV Watts.
    Of course, PV Watts is based on actual data (include weather, dust storms and panel temperature--As I recall)... So if you have, for example, afternoon thunderstorms during the wet season, changing tilt and/or direct facing (say more South East) may give you better harvest during stormy weather.
    One of our retired members here lived in Florida, and found facing more south east gave him better overall harvest (both because of weather and because panels were colder in the morning vs afternoons). However, the utility folks "pushing" GT solar wanted afternoon harvests (when folks turned on AC systems in the offices and after they headed home)--And they were surprised to see the variance in harvest results.
  • alcatel99
    Thanks Bill
  • SethandBecca
    SethandBecca Registered Users Posts: 20 ✭✭
    I am still trying to figure the angles out for my panel array. What is the optimum angle for Winter and summer for 38 degrees lat.
    Seth&Beth, welcome to the forum.
    What is the nearest major city for your location?
  • littleharbor2
    Get the "Solar Tilt" app. It is an amazing tool. Knows your location or you can enter any location and day of the year for optimum panel tilt. Even has a built in angle gauge for setting the angle of your panels.
    Also consider your winter solar hours (few) vs summer hours.  I leave my panels set for winter, all year long. There are so much more hours in summer, I don't need any extra harvest.
     (off-grid)
    Dave Angelini Solar Expert Posts: 6,753 ✭✭✭✭✭✭
    edited April 2021 #49
    Unless there is a wildfire  ;)
     Another old benefit of summer is the longer hours of power can make your battery bank appear larger as it has to work less. This can make cooling easier offgrid. Another life sustaining feature of cooling, is keeping the smoky air outside your home.
    Fighting a fire at night also is easier in Summer with the longer hours of sun power and light. Not looking forward to this stuff either! Another drought here and I keep hearing it is pretty bad everywhere west of the Mississippi.  YUK !
    Our area is doing alot of Prescribed burning. Going to one tomorrow!
  • SethandBecca
    Pueblo Colorado would be the nearest major city.
    This a "simple" solar calculator--It gives you several options/configurations:
    Note this calculator uses the "angle from vertical". Pretty much everything else uses the "angle from horizontal"--Which makes things easier for "setting angle to lattitude" (52 degrees from Vert = ( 90-52= ) 38 degrees from horizontal.
    Pueblo
    Measured in kWh/m2/day onto a solar panel set at a 52° angle from vertical:
    JanFebMarAprMayJun
    4.49
    4.93
    5.61
    5.74
    5.88
    6.10
    JulAugSepOctNovDec
    5.79
    5.62
    5.95
    5.72
    4.68
    4.30
    You can play with the numbers and see how things are affected. It is "good enough" for our planning (within ~10% of "real" numbers, IMHO). And trying for more accuracy is not really helpful--Weather, clouds, humidity, temperature, dust on panels, etc. all affect numbers by 10% or more over days/weeks/months/years).
    A more sophisticated program that makes things a bit more complicated:
    38 degrees from horizontal, facing south, 52% overall efficiency (for off grid AC power systems).
    RESULTS
    Print Results
    System output may range from 1,027 to 1,090 kWh per year near this location.
    Click HERE for more information.
    MonthSolar Radiation
    ( kWh / m2 / day )
    AC Energy
    ( kWh )
    Value
    January5.037913
    February5.657913
    March6.6310116
    April6.689816
    May6.609616
    June6.879315
    July6.639215
    August6.769415
    September6.889515
    October6.089015
    November5.297813
    December4.927813
    Annual6.171,073$ 175
    User Comments
    Find A Local Installerdownload Download Results:   Monthly   |   Hourly
    * Caution: The PVWatts® energy estimate is based on an hourly performance simulation using a typical-year weather file that represents a multi-year historical period for Pueblo, CO for a Fixed (open rack) photovoltaic system. The kWh range is based on analysis of a nearby data site described here.
    The estimate for the value of this energy is the product of the AC energy and the average retail electricity rate. This value is useful for basic comparisons but does not account for financial considerations in a cash flow-based analysis. All of these results are based on assumptions described in Help that may not accurately represent technical or economic characteristics of the project you are modeling.
    Location and Station Identification
    Requested LocationPueblo colorado
    Weather Data Source
    Lat, Lon: 38.25, -104.62 1.2 mi
    Latitude38.25° N
    Longitude104.62° W
    PV System Specifications (Residential)
    DC System Size1 kW
    Module TypeStandard
    Array TypeFixed (open rack)
    Array Tilt38°
    Array Azimuth180°
    System Losses48%
    Inverter Efficiency99.5%
    DC to AC Size Ratio1
    Economics
    Average Retail Electricity Rate0.163 $/kWh
    Performance Metrics
    Capacity Factor12.2%
    I have not played with all the numbers/options... The above is setup for Grid Tied utility interactive systems which are much more "efficient" vs DC off grid power systems.
    You can see the PVWatts program seems to give about 10% higher "hours of sun" per day (roughly 1,000 WH of sun per sq meter = "1 hour" of noon time equivalent sun per day.
    One of the neat things about PVWATTS is you can download a spread sheet of the hourly power productions for a "generic/average" years worth of data.
    The above assumes a 1,000 Watt Array (smallest number PVWATTS accepts). And to compare with our manual calculations using January as an example:
    • 5.03 "hours of sun" per day (PVWATTS) * 0.52 off grid AC system efficiency * 1,000 Watt array = 2,615 WH per day (Jan average)
    • 2,615.5 WH per day (Jan) * 31 days = 81,085 WH per Jan = 81 kWH per Jan (vs 79 kWH per day from PVWATTS using "my" deratings for PVWATTS).
    • 4.49 hours of sun per day (Jan from SolarElectric link) * 0.52 off grid AC system eff * 1,000 Watt array = 2,335 WH per day (2.3 kWH per day)
    "How you run your system" (day/night power usage, type of batteries, depth of cycling, do you clean dust of panels, etc.) are all ~10% variation too.
    A couple of items to think about... With Lead Acid batteries, they need "hours of sun" "on charge" per day... You cannot dump 3 hours of "fast charge" into a discharged Lead Acid battery bank and force a recharge to 100% without slowly damaging the battery (high current, high gassing, high temperatures). So--For folks that are off grid and need more energy in the winter--Using a mechanical tracking array to follow the sun across the sky gives "more time on charge" during the day (great for lead acid batteries--lower peak charge current, longer time on charge). An option to the mechanical tracking (since solar panels are so "cheap" these days)--Create two arrays, 1/2 facing south east, the other 1/2 facing south west... You lose a bit of overall harvest, but increase hours on charge (cheap panels=>Buy some more panels).
    Something to think about is using LiFePO4 (or similar) Lithium Ion batteries... They simply need Amps*Hours to fill (nearly 100% efficient). So they can take a large array with winter sun (fewer hours on charge). Li Ion batteries have other issues (don't work well below ~40F, need battery management system to reduce risk of damage, and are still very expensive vs lead acid batteries--Although longer Li Ion life does reduce the cost "spread").
    And sizing for variable weather conditions... Never plan on using 100% of a solar array's predicted output every day... The numbers are an "average"--Some days more, some days less... Some days much less (stormy weather). To minimize run time of your genset, and stresses on your family--Another suggestion... Break your loads into "base loads" (loads that need to be powered every day for living/work) and "optional loads" (washing machine, water pumping for irrigation, movie night, etc.). Typically suggest that base loads run at 50% to 65% of predicted output, and optional loads run on sunny days.
    In the end--Sizing the array should take many factors into account. Make sure you "know your loads" (Watt*Hours per day, seasonal usage, base vs optional loads, etc.)... And do a full "paper design" first, before you go out and start buying hardware. There are "configuration" issues to make sure everything "plays well together"... It is very easy to buy hardware "on sale" that ends up not working well/or at all/for your needs.
    There are no "right answers"--Understanding the math and assumptions under the calculations will help you decide your actual system design. And especially for off grid power--Yes, you will most likely end up with an "over sized" solar array--Solar is highly variable, and batteries need to be kept "happy" (operating within voltage/current/state of charge parameters). Batteries being some of the most expensive components, and the easiest to "murder" if operated incorrectly (typically under charging / over discharging is what kills batteries for most folks).
    Seth and Becca,
    I suggest you start your own thread/discussion, and we start talking about your needs/system design in detail.
    It makes things easier to follow--Just your Q&A, and not others' earlier in the discussion.
    It looks like you have >~3 hours of sun per day--That is great for solar (don't have to dramatically over size the solar array for poor winter sun/solar harvest).
  • SethandBecca
    I will start a new thread titled CO solar.
    Thanks for the suggestion.
