Partial solar eclipse effect
solar_dave
Solar Expert Posts: 2,397 ✭✭✭✭
See attached, the green line make this weird upward dip this afternoon.Attachment not found.
Re: Partial solar eclipse effect
Dave, what is that green line representing? No legend...
Re: Partial solar eclipse effectwestbranch wrote: »Dave, what is that green line representing? No legend...
The green line is the solar output. The red line is my main house loads, the light blue line is the Volt chargers, the pink line is the loads from the office/shop building, the yellow line is the voltage and the dark blue line is the NET electric.
I just thought the partial solar eclipse made for an interesting distortion of the normal bell curve (green line around 1500 hrs). -
I saw that and have been pondering what caused the positive movement in the line, edge effect?
Re: Partial solar eclipse effectwestbranch wrote: »I saw that and have been pondering what caused the positive movement in the line, edge effect?
the spike is probably the utility switching in stuff getting the Hz out of sync just a bit, note the Voltage is noisy that day. So that would be one inverter dropping out to re-qualify. The smooth distortion of the bell curve is the eclipse.
- 218 Forum & Website
- 646 Solar Water Pumping
- 813 Wind Power Generation
- 598 Discussion Forums/Café
- 72 Construction
