reversable conversion of chest or shelf freezer to fridge for less than $15.
john p
Solar Expert Posts: 814 ✭✭✭
If you are contemplating converting your chest or shelf freezer to a fridge here is simple and cheap solution.
This is actually not a conversion at all its a simple add on so the freezer has no alterations.
Parts needed.
1plastic box about 8x4x2 in
1power cord plug too suit your country bare wire other end
1 wall mount power outlet to suit freezer power plug
1used/new thermostat and sensing tube from old ?fridge.
1 relay that has mains voltage operating coil.ie 120 or 240v ac to suit your country rated at least 10a
Construction is simply drill 3 holes in box ,one for sense tube and one for input power cord and one for thermostat control shaft
mount the thermostat and control knob
connect one input mains wire to one term of thermostat and to one of the the N/O term of relay
connect the other mains input wire to outlet socket and to one term of relay coil
connect the other thermostat term to coil term of relay.
connect the other N/O terminal of relay to outlet socket
The operation is simple the tube of thermostat is mounted with either silicon or gaf tape to inside of freezer the thermostat is set to tep you need. set the freezer control to full on.the thermostat switch operates the relay .It must have a 120 or 240v coil rating same as what your freezer is. And the contacts need to be rated at least 10 a I used a aircon relay "cheap" rated 30a" cost about $8.
The freezer just plugs into the power outlet on the box and its power cable connects to the usual freezer wall outlet.. Thats it.
use a thermometer to find a setting of about 3deg C for the "new" fridge
Photos are of the prototype done about 5 yrs ago and in constant use ever sinceand soon will be made into a nice neat box and mounting >>mmmmm
Parts needed.
Re: reversable conversion of chest or shelf freezer to fridge for less than $15.
Hi, John,
I've become my chest freezer in a refrigerator, but without adding or buy anything ...
Simply you can set the control "coarse" with have most thermostats, to place in a 5ºC temperature range, so it can work directly as refrigerator, without anything more ...
you can see my post here:
http://forum.solar-electric.com/showthread.php?18685-converting-a-chest-freezer-(top-load)-in-a-refrigerator-with-a-freezer!
Here I learned to re-adjust my thermostat:
http://www.homebrewtalk.com/f51/guide-set-internal-chest-freezer-thermostat-32f-eliminate-external-control-249612/
this will work fine!...
I only need to add the freezer section, that I want to work with a peltier system, located inside the chest refrigerator...
I'm on it! ...;-) -
Re: reversable conversion of chest or shelf freezer to fridge for less than $15.Here I learned to re-adjust my thermostat:
Thanks, Lots of good info there!Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
I had read that HomeBrew thread ( I am a member there) as I was going to build a Keg-erator before I moved last year and went off grid. Hard to justify powering a kegerator from my off grid system.... or is it?:D -
Re: reversable conversion of chest or shelf freezer to fridge for less than $15.I had read that HomeBrew thread ( I am a member there) as I was going to build a Keg-erator before I moved last year and went off grid. Hard to justify powering a kegerator from my off grid system.... or is it?:D
you mean that we are not allowed to make bier, when we living off-grid???...
it needs so much energy waste, to make bier???...
very bad news for me!...i do not know the process yet, but I had to look forward to one day make my own beer!... -
Re: reversable conversion of chest or shelf freezer to fridge for less than $15.you mean that we are not allowed to make bier, when we living off-grid???...
There are also processes for making beer that do not require so much refrigeration. Look up "steam beer" for more information.
Or make your beer in the winter only. :-)SMA SB 3000, old BP panels. -
Unicornio, Beer making uses almost the same process as making wine, just that things happen faster ( drinking?) as one wants to have a few bubbles left in the beer and most of us like our wine flat (no bubbles) unless you like 'bubbly' champagne...
I have to learn to make my own beer! ... but yeah!...i know very well the method of making wine! ...;-)
but we will stop the offtopic here!...;-)
- 628 Discussion Forums/Café
