Is This the Key to Vastly Better Batteries?
Shadowcatcher
Solar Expert Posts: 228 ✭✭✭
http://www.technologyreview.com/news/428036/is-this-the-key-to-vastly-better-batteries
"Jerry Martin, CEO and cofounder of a small startup in Colorado, says his company—Boulder Ionics—is developing a way of making a type of electrolyte that would enable high-performance batteries. The electrolyte, made from ionic liquids—salts that are molten below 100 ⁰C—can operate at high voltages and temperatures, isn’t flammable, and doesn’t evaporate. Ionic liquids are normally expensive to produce, but Boulder Ionics is developing a cheaper manufacturing process."
Re: Is This the Key to Vastly Better Batteries?
Vaporware, till till they take a prototype on the road.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 628 Discussion Forums/Café
