Home-made SOC gauge
cptdondo
Solar Expert Posts: 103 ✭✭✭
I have a solar setup in my RV. I also have a lot of hardware left over from other projects; enough to make a really nice monitor for the voltage, current, and temp of the batteries.
I am looking for some software examples on how to calculate the approximate SOC based on monitoring voltage, current draw/charge and battery temp. I know about Peukert and I've found various ways to use it to approximate the SOC. I can't help but think someone has published the source to a program that does this, though....
Any suggestions?
Any suggestions?
Re: Home-made SOC gauge
The most information I have seen on this subject is on the SmartGauge website:
http://www.smartgauge.co.uk/technical1.html
And, there is another voltage only gauge from Midnite Solar:
http://www.midnitesolar.com/products.php?menuItem=products&productCat_ID=27&productCatName=Battery%20Capacity%20Meters
And here are some graphics about SOC and various battery voltages:New poster "leaf" has a really nice set of charts that compare battery voltage against different rates of discharging and charging (as well as resting voltage readings).
I don't quite a agree with the resting voltage line (I think the voltage is a bit low)--But it shows how to estimate a battery's state of charge while operating.
Note, where the charts "flatten out"--the room for error estimating state of charge is pretty high.
That is the basics I am aware of...
I'm trying to do the same thing. So, I made a lot of observations on my batteries.
When charging, this is absolutely unreliable. Probably +-30% is the best you can do.
When discharging, you can more or less predict SOC. However, there's a "memory effect". When a load is suddently removed, it may take few minutes (if not longer) to restore the "correct" voltage level. When a load is applied, the voltage drop may be gradual and the voltage may dip further than it should. So, you need to be creative, monitor load history and do appropriate adjustments. You can use curves that BB has posted, but most likely you will need to adjust them to your particular batteries.
I decided to relay more on AH-counting, which will give better results. When you do not get to fully charging state very often, AH-counting is likely to go haywire. For that, I will use SOC predictions to detect when the batteries are too low. I haven't written the software yet.
- 218 Forum & Website
- 185 Solar Information links & sources, event announcements
- 647 Solar Water Pumping
- 813 Wind Power Generation
- 599 Discussion Forums/Café
- 73 Construction
