NTP Wind Power Variable Pitch HAWT
Powers
Solar Expert Posts: 36 ✭
Hello,
Please check out our 100 % US made wind turbines.
www.ntpwind.com
http://www.youtube.com/watch?v=c5u98Qm7eaM
Thank you,
Charles Spoto
NTP Wind Power Inc can be reached by phone, fax, and e-mail.
Crystal Lake, Illinois 60014
Email; ntp@ntpwind.com
WWW.NTPWIND.COM
Fax Number (815) 568-8478
24-Hour Cell / Int Charles Spoto 815-345-1931
www.ntpwind.com
Thank you,
Charles Spoto
WWW.NTPWIND.COM
Re: NTP Wind Power Variable Pitch HAWT
I have moved this post to its own thread... "Powers" has posted a link to their variable pitch horizontal axis wind turbine which (according to the spec. sheets) will limit turbine RPM above ~27 MPH (will keep generating in higher wind speeds without shutting down/furling/braking).
If anyone has questions or experience with this turbine--Please feel free to post.
Re: NTP Wind Power Variable Pitch HAWTI have moved this post to its own thread... "Powers" has posted a link to their variable pitch horizontal axis wind turbine which (according to the spec. sheets) will limit turbine RPM above ~27 MPH (will keep generating in higher wind speeds without shutting down/furling/braking).
I like that the video shows the turbine mounted on a tall enough tower to be "real". But just look at the wind speed as shown by the motion of the treetops.
You still need a good wind survey to decide whether to install a turbine or not.SMA SB 3000, old BP panels. -
The hub is at 65'. This is a customers site in NW Illinois. This site is one of our original test sites. We like this site for testing because it has trees that tower up to10 feet below the hub to the N and NW. This site is full open to S/E, S/W and S.
As a test site the North winds cause the mil to hunt adding extra load and fatigue. After one year, this extra load hasn't caused any issue. -
It looks a lot like Windspot wind turbine
- 628 Discussion Forums/Café
