need help lyncom controller
drandlem
Registered Users Posts: 3
I have a lyncom controler model # PV12M it is 10 to 12 years old I lost my manual and I need to know how to change it from a wet cell battery to a sealed.
Thank you David
Thank you David
Re: need help lyncom controller
Google is you friend !!
www.kyocerasolar.com/pdf/specsheets/lynpv12_m.pdf
Is this it ??
I would fire off an email to Kyocersolar. -
thanks I have contacted Kyocersolar. they have no more info and no one in the company knows how to change it over. -
i was trying to see if i could make things out on the pdf pic to help you out with, but that is a lousy pic. do you think you could submit to us a better pic or if somebody has a link to a better pick (if not the actual info you need) as it may be helpful in determining that info. morningstar sunsavers have a jumper for this purpose and i'm wondering if the lyncom may be the same for it looks like similar results that a diode would yield.
a external diode of the proper current rating could drop the voltage the needed amount to give you voltages in the ballpark needed for agm style batteries, but the eq function may still engage on the controller and that you don't want. in the meantime play with it as the voltage will be held lower for a charged battery if you come across the correct way of doing it. -
Re: need help lyncom controllerthanks I have contacted Kyocersolar. they have no more info and no one in the company knows how to change it over.
A bit (2 yr) late 8).
I have a 3-page "Operator's Manual" for a Lyncom N-series. It provides the following information to configure for flooded or sealed gel-cell batteries. It may not apply to your controller:
"3. Double check the type of battery that the controller is to be connected to: flooded lead acid battery or the sealed gel-cell battery. The charging voltages are different for the two types of batteries, therefore it is important to set the PV controller to match with the type of battery in use. The battery type selection is achieved by the use of a jumper plug accessible through a round hole in the top end plate of the controller. To set the controller for flooded lead-acid batteries, remove the small jumper plug with needle nose pliers. Do not do anything if you have the sealed gel-cell type battery. The controller is set for this type of battery at the factory."
HTH.
BobW -
Thank you for the information--At least it is now "on file" if anyone else needs the information.
The original poster has not been back for over two years, so they probably will not see this post.
Thank you for the information. I have been ill and have not been online for awhile. -
Drandlem,
I am very sorry to hear of your health problems... I hope you are better now.
- 218 Forum & Website
- 646 Solar Water Pumping
- 813 Wind Power Generation
- 598 Discussion Forums/Café
- 72 Construction
