Used 600 AH 2 volt Cells
H2SO4_guy
Solar Expert Posts: 213 ✭✭✭
I picked up 12 of the C & D technology cells model RHD-600 that are rated 600 AH @ the 8 hour rate. The float voltage is between 2.25 and 2.27 VPC. I am wondering about a charge voltage to bulk and absorb them at. These were made in September 2005 and are within .01 volts of each other. I am hoping they get more in like them so I can setup a 48 VDC string. I am currently limping along on some 12 year old Lucent AGM's that are also between 2.25 and 2.27 VPC float and I set the bulk at 14.4 volts and they seem to be happy there.
These cells weigh 104 pounds each, so I can move them by myself which is nice and I made a deal with the battery place for $635 for all 12, so it isn't too bad of a deal, just don't have anything 24 volts to use them in. May have to setup 2 strings of 12 volts, but they may get more of them. I was there too late and they had already sent off 2 skids of 12 each of them to the smelter (I wanted to cry!!!) Worst case I can scrap them for $400, so it is not a bad deal either way.
What are some others setting the bulk and absorb for on AGM's? If there is any interest in the Kansas City area, I will be glad to pass along the information.
12K asst panels charging through Midnite Classic 150's, powering Exeltechs and Outback VFX-3648 inverter at 12 and 48 volts. 2080 AH @ 48 VDC of Panasonic Stationary batteries (2 strings of 1040 AH each) purchased for slightly over scrap, installed August 2013. Outback PSX-240X for 220 volt duties. No genny usage since 2014.
Re: Used 600 AH 2 volt Cells
I have the Concorde PVX-4050HT in a 24-volt bank. The absorb is set for 28.8 and float is 26.4. I also have a 12v bank configured of 4 Optima D34's. Their absorb is 14.4, and float is 13.2. -
h2so4,
that's a good question that you should pose to c&d. they say for discharges up to 80% dod so it would not make sense to float charge it back to a full charge.
http://www.battery-usa.com/Catalog/12_371.pdf
now i did find info in a round about way by looking at their chargers.
http://www.cdtechnopwr.com/getdoc/89cedafa-83ee-46f8-9220-1943721eac3a/ARE-Legacy.aspx
it seems 2.33v/c is for an eq voltage. this is 13.98v so i would assume it to be good up to there.
note-i never heard of these,
ferroresonant float rectifiers
