little generator project...old wind genenerator
t00ls
Solar Expert Posts: 245 ✭✭✭
this is from my wind project I abandoned...couldn't get the tower any higher right now
7 in. pulley on motor
Honda 5hp
exhaust baffle...so the neighbors don't complain
stainless steel scrub pads
Attachment not found. ...the pvc gets a little hot an flimsy, I'll change to metal ...it's what I had on hand
before it is running
Attachment not found. wont let me load the other pics in this window ....look down here\/ or up here if your logged in/\
Honda 5hp
Re: little generator project...old wind genenerator
after the motor is running ....only part throttle. This setup will put out 1200 watts without burning up the generator
I also changed the charge controller from auto sweep to manual and set it at 67.0 volts -
nice setup! looks like a fun project. -
That is the best use of a wind PMA I have seen so far.Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
- 218 Forum & Website
- 185 Solar Information links & sources, event announcements
- 647 Solar Water Pumping
- 813 Wind Power Generation
- 599 Discussion Forums/Café
- 73 Construction
