rotary electrical connector
I've been looking at plans for diy wind generators. None of the plans for horizontal generators address a need for a rotary electrical connector in the pivot so the generator can follow the wind 360 degrees without wrapping the power wires around the tower. The only rotary connectors I can find look to be pretty expensive. I am wondering if there cheaper options or other means to solve this problem.
Re: rotary electrical connector
The website and forum below are dedicated to wind power--Perhaps they have some better sources/information for you about your slip rings and DIY Wind questions:
http://www.otherpower.com/
http://www.fieldlines.com/board/
brushes come to my mind. -
Re: rotary electrical connectorI've been looking at plans for diy wind generators. None of the plans for horizontal generators address a need for a rotary electrical connector in the pivot so the generator can follow the wind 360 degrees without wrapping the power wires around the tower. The only rotary connectors I can find look to be pretty expensive. I am wondering if there cheaper options or other means to solve this problem.
Often, the cables are dropped down through the tower, with an Anderson connector at chest level, where there is an access port into the tower. Weekly, or monthly, you open the port, un-plug the connector, and unwind the twists. Seems to work better than brushes and slip-rings.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 628 Discussion Forums/Café
