shurflow on solar without batteries?
lotek
lotek Solar Expert Posts: 65 ✭✭✭✭
I ran across an item I thought would allow me to run a shurflo 2088 pump directly form a solar panel. I have lost that data and am not sure what it did. Is there a product that would regulate voltage from a solar panel to the pump by not turning on until voltage was at 12/24v and turn off when voltage got low, that would allow water transfer when the sun was shining?
Im entertaining the idea of pumping to a tower at a slow rate, by using a pressurized tank, and limiting outflow to about 1/2 gal a min. this would insure intermitent run time for the pump and insure I didnt draw down the well to quickly.
    Re: shurflow on solar without batteries?
    Look for Linear Current Booster (I think this is what you are asking about)...
    http://www.solar-electric.com/7amplincurbo.html
    Our host also has a used DL-10B Dankoff LCB (larger). There is a PDF manual too.
  • john p
    john p Solar Expert Posts: 814 ✭✭✭
    i have so far from the deka gel monobloc 6 volt 210 amphour. 300 bucks each. I would need 4 to have 24 volts. Thats 840 amp hours per gang of 4 correct?
    close but no cigar
    you still only have 210ahr
    I think C.T. was a spammer of some sort. Banned and deleted.
