Combiner for PV cable to DC load center
solaris3000
Registered Users Posts: 24 ✭✭
Looking for a way(economical) to adapt the stranded core + and - PV leads to a 12gauge solid core wire that will be connected directly to my SquareD load center and breakers.
Thanks for your time.
Re: Combiner for PV cable to DC load center
Do you mean adapt the standard PV MC3/4 connectors to regular wire? That one's easy; buy an MC extension cable and cut it in half. You get a (+) pig tail and a (-) pig tail. The wire ends can be spliced to regular wire. These splices should be out of the weather, of course. Solder on & heat shrink wrap is good. -
So I just need to splice/solder the + and - negative leads of the MC4 to my solid core AWG 12 + and - leads.
Works for me,,and thanks again....
regards
Brian -
Re: Combiner for PV cables to DC load center
What about if I were to use a BUSBAR of some kind. I am thinking if I add more panels in the future I could run the PV cables to it and easily expand.
One for positive and the other for the pv negative cable. Then from the bus bars use shielded solid copper core AWG 12 or similar into the DC Load center via plastic conduit.......etc...etc..
Not sure if this is will work,, Feedback is greatly appreciated.
If the wire is long enough, can run directly to the circuit breaker. The breaker can have solid or strained wire. -
Re: Combiner for PV cable to DC load centersolaris3000 wrote: »Looking for a way(economical) to adapt the stranded core + and - PV leads to a 12gauge solid core wire that will be connected directly to my SquareD load center and breakers.
- 218 Forum & Website
- 647 Solar Water Pumping
- 813 Wind Power Generation
- 598 Discussion Forums/Café
- 72 Construction
