Orientation of Solar Panels
With54
Registered Users Posts: 21 ✭
Do both 12 volt panels connected in series have to be pointed in the same direction or could one be pointed more to the east to take advantage of the morning sun and the other to the south?
Thanks for your input.
Re: Orientation of Solar Panels
panels in series, need the same oriention.
If in parallel, with a PWM style controller, then yes, that is possible.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Ideally both in the same direction. Otherwise it's the age old problem of "shading" on panels.
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
