I need a lesson on Racks/Mounts
Knd870
Knd870 Solar Expert Posts: 32
I've been doing a lot of reading on this forum but haven't found much info on roof mounting systems. Unirac seems to be the industry leader, but IronRidge says that their rails of strong enough to nearly double the span of the Unirac, greatly reducing roof penetrations. For my application there will be minimal snow load and 90 mph design wind load, and I think the IronRidge design tool indicates that for most panels you could anchor at 8 feet OC.
In general what are the priorities in selecting a mounting system? To me it would be roof penetrations - 1st, ease of assembly 2nd, with both of these balanced against cost. Also, I'm assuming aluminum so corrosion should not be an issue - should it?
What else am I missing?
    Re: I need a lesson on Racks/Mounts
    Knd870 wrote: »
    ..... Also, I'm assuming aluminum so corrosion should not be an issue - should it?
    Aluminun should be anodized, and compatable fasteners used, within 20 miles of the ocean, salt fog really eats up raw aluminun.
  • Jburgess
    Jburgess Solar Expert Posts: 130 ✭✭✭
    Knd870 wrote: »
    By reducing the number of roof penetrations, you are increasing load at each mounting point. I was going to go that route, but my architect said too much loading on the trusses.
  • wdegrace
    wdegrace Registered Users Posts: 8
    You know, unirac also has the HD rails and double L-foot in which case they could be installed with 7-8 foot spans as well. However, that is a great point about point loading...the larger spans create a greater psf on the trusses.
    Unirac is actually very easy to install the biggest hurdle to overcome is whether or not you have all of the pieces you need for the array. If the layout happens to change on you - you may be overnight shipping endclamps and weebs.:roll:
  • ggunn
    wdegrace wrote: »
    Or keep lots of spares. We do.
  • Knd870
    Thanks everyone. One last question:
    How important is it to have a space between the panels and the roof (I'm exploring a residential sloped roof system). I know that most racking systems don't have the panels on the roof, but what is ideal height above the roof? I've read that air circulation is important to help keep the panel temperatures down, but how much space is needed?
    Usually 5-6" is "enough" spacing... Roughly, you will lose around 0.3-0.5% per degree C (probably closer to 0.5%/C for most panels).
    Panels are rated at ~70F (room temperature)--but as soon as sun hits the panels, they start heating up. The assumed worst case heating is around 35C (63F).
    • 0.5% * 35C rise = ~17.5% loss in power (assume 20C rating and 35C rise)
    So, the difference is perhaps 25C rise vs 35C rise? Assuming worst case 0.5% derating, the difference between flush and free air mount 10-20 C or 5-10% increase in power output (maximum) assuming air circulation from the rear...
    Perhaps somebody here can take an IR thermometer to the front and rear of their panels and let us know the readings on a hot/calm air day and tell us their actual measurements.
    I am not sure how much heat is radiated through the rear of the solar panels--they are usually plastic backed which tends to restrict heat flow.
  • Knd870
    Thanks Bill. Once again you have provided some valuable data. I hope someone that has a system does take this measurement.
  • jcgee88
    jcgee88 Solar Expert Posts: 154 ✭✭
    I did that last Summer:
    Air temp: 95 degrees
    PV module temp: 118 degrees
    Exposed roof temp: 145 degrees
    Shaded (by panel) roof temp: 124 degrees
    On the topic of the rack itself, I have Unirac, but if I had to do
    over again, I would give strong consideration to:
    http://www.solarflexrack.com/
    John
  • Knd870
    jcgee88 wrote: »
    John
    thanks John,
    How much space is between your roof and the panel? Does this shading have a positive impact on your A/C?
    Bill,
    If I did the math correctly then this is only about a 13 degree C rise, so John's efficiency loss is between 3.9% - 6.5%?
  • Knd870
    jcgee88 wrote: »
    IOn the topic of the rack itself, I have Unirac, but if I had to do
    John
    John,
    I'm almost certainly going to have someone do a turnkey installation of the system, as it will be going on new construction. Should I be concerned with which system is being used, as long as it meets the structural loading, is grounded, has the correct corrosion capabilities?
    I'm assuming that the value of an easy to install racking system is for the initial install and there is no other advantage - is this correct logic?
  • jcgee88
    Knd870 wrote: »
    I have two strings, one is the normal height, 5-6" inches from
    the roof. The other is tilt mounted to convert its northern
    exposure to a southern one. I measured the PV panel
    temperature on the panels' top surface, and the shaded roof
    temperature just under the lip of a panel (several
    locations/readings were made to ensure accuracy).
    As far as A/C impact, it's hard to tell. Even though a roof
    array can appear prominient on your roof, the actual square
    footage relative to the roof is still quite small. In my case,
    it's about 10%. So if they were perfect solar heat reflectors,
    the best I could get would be a 10% reduction in heat
    transmission to my attic. That reduced heat is then further
    blocked by my R30 insulation before it becomes A/C load. Of
    course, the panel is not a perfect 100% reflector, as seen, it
    reduced the roof temperature by 40% over the ambient air
    temperature. Net net, saving a smidge off of your A/C is
    all good but the amount isn't discernable on your electricity bill.
    John
  • jcgee88
    Knd870 wrote: »
    John,
    To paraphrase, what you are saying is that if the end result is
    the same, who cares how they got there? My approach is that if
    there is a better way to do things and the contractor shares
    some of the benefit of that better way with you, then you should
    consider doing it the better way. That being said, not all
    contractors are familiar with this product (mine wasn't), and
    even if they are, they might just pocket their labor savings.
    I'd say that you still gain by reducing job site errors and
    accidents. On the former, let's say the installer mis-locates
    a Unirac anchor point and drills through your roof in the wrong
    place. Yes, he can fix that, but now your roof has additional
    potential for leaks. On the latter, accidents do happen (one
    did during my install), and the less time you have people in
    high risk locations (=the roof), the less chance of their falling or
    doing some damage to your home.
    I like the concept of Solarflexrack's product because:
    1. The rack is essentially complete from the factory. There's no
    leveling/measuring that you have to do to make the various rails
    parallel to each other. Where the installer places the rack footings
    is the exact place you need to do the roof attachment. Both of
    these features result in less opportunity for error.
    2. Once at the site, you unfold the completed assembly, rather
    than having to bolt it all together yourself. [You still have to
    do the anchoring to the roof.] For my site, it took two installers
    a full day to install my Unirac. I bet it would have taken them
    at most two hours if they had used the flex rack. At his $80/hr
    labor rate, he could have reduced his price by almost $1,000.
    3. Lastly, their system gives you an option to slide the PV panel into
    the rack, rather than anchoring each panel with four bolts. The
    former operation takes seconds, the latter takes several
    minutes. Sliding them in also means that the panels automatically
    align with each other horizontally (for a nice appearance). My
    installer had to individually adjust the height of the anchors after
    the initial panel installation to achieve this same result (all roofs
    undulate, hence the need for this).
    So the above is the theory. I didn't know about Solarflexrack when
    they installed my Unirac, so I don't have a way to know how theory
    and practice meet in this case. The end result should be largely the
    same for both...in that case, absent a huge difference in price, I would
    want to go with the one that is easier and quicker to install and
    has inherently less opportunity for error.
    John
  • Knd870
    John, Thanks. What I was trying to ask is, does the mounting system matter 5 - 10 years in from a replacement/maintenance/reinspection aspect. I was aware of the advantages of more work being done at the factory both is cost savings (whether they turn into mine or not) safety, screwups, etc.
    I wasn't sure if there were some other benefits that might be there in the future, such as if you need to reroof in the future that might be of value.
    Do the utilities reinspect over a certain timeperiod or once it passes it good for it's lifetime?
    Some long term considerations may have some impact on the racking system, was what I was asking.
  • jcgee88
    Knd870 wrote: »
    I'd say there are two longer term benefits of Solarflexrack, but
    these are somewhat modest. First is that if you do need to
    re-roof, just as it is easier to install, it will be easier to de-install
    (and a week later re-install). By the way, I've had three roofs on
    my home during my 20-year ownership, so re-roofing is a distinct
    possibility. Second is that if you add significant capacity later,
    being modular, the Solarflexrack should be easier to "just
    plug in" (see Solarflexrack's video on how they do modular
    expansion). On the other hand, if you're doing just a small
    increase, appending to Unirac rails is not hard (I just went
    through that when I added two panels).
    As far as utilities re-inspecting, my utility inspected upon
    installation and the net metering agreement with them
    says that they "reserve the right" to come back for additional
    inspections. This reserved right is to enable them to determine
    whether I have made a major change without telling them.
    They also require me to test the DC cut-off switch at least
    once a year, and they can request that I provide documentation
    that I did the test. Other than these two items, there's no
    expectation on my part that they will ever come back.
    John
  • Knd870
    jcgee88 wrote: »
    John
    Thanks John, I appreciate the thoughtful detailed answer. It is also very reassuring to get first hand accounts of your experiences, since all of this is so new to me.
