USB, Laptop charger
mr.radon
Solar Expert Posts: 158 ✭✭✭✭✭
Anyone have a recommendation for a good portable (backpack) solar charger with a USB connector?
I guess it would have to be rugged, lightweight. Maybe 1-3 Watts.
I've thought of getting a pannel off e-Bay and adding a 5V regulator and USB connector.
Anyone use a product like this?
Re: USB, Laptop charger
You may need a large capacitor (or small battery) at the 12V side, to stableize the voltage, and use a DC-Dc convertor to get your 5V. A simple linear regualtor LM7805, will waste about 2/3 of the power as heat, and you ge1 1/3 of the power at the output. (power as in watts, not volts)Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: USB, Laptop chargerI've thought of getting a pannel off e-Bay and adding a 5V regulator and USB connector.
check out this regulator
http://www.dimensionengineering.com/DE-SW050.htm
I have used them in several projects powering 5 volt cameras, 5 volt weather stations from 12 volt battery but should also work with tiny 12 volt battery and small direct connect solar panel. -
Those fold up portable PVs are hella expensive.
I'm seriously considering getting on of these:
http://www.thinkgeek.com/gadgets/travelpower/e193/
Probably heavier than I'd want to pack though (if I still packed...I don't, I'm too old and fat for that anymore). -
MikeO,
thanks for sharing/posting the link.
i've got a couple little projects..looks like the units might work great!
james -
I bought a 9v 1.5w panel. going to hook it to 6 1.2v aa batteries a Schottky diode a 7805 volt reg and a usb port.;) -
Well, I tested the design. It works real well.
Looking for a good light weight potting material. Suggestions?
Used the mentioned components, however, I added a "OFF" switch since the 7805 draws 8ma when not in use. Not good ofr long term sotrage.
The 1.52W panel was able to charge the batteries from 30% charge to 80% charge in a day (November). Given the long expidition will be Africa in the summer she should be able to recharge the battery pack 100% durring the day.
- 626 Discussion Forums/Café
