Difference between Magnetic South & Solar South?
BilljustBill
Solar Expert Posts: 219 ✭✭✭
As a beginner, do I understand that Magnetic South and Solar South are not the same thing?
Finding the Magnetic South using a military compass, it appears the South roof site I have is facing about 7 or 8 degrees East of the compass needle.
Using one of the online Angle calculators, I get this:
In the whole scheme of things, 8 degrees may not mean much for an Off Grid 1kw fixed roof array. Although, not knowing Solar South might mean that it's actually 14-16 degrees Longitude off on the 22-1/2* roof pitch. Then, as I plan for installation of the fixed array, I would have to angle the panels as well as tilt them for the best Winter production....
If you know the Magnetic South, how do you know where the Solar South is?
Thanks,
Bill
Latitude: 32.761992
Longitude: -97.688549
Thanks,
Bill
Bill
Re: Difference between Magnetic South & Solar South?
This might help http://www.builditsolar.com/SiteSurvey/FindingSouth.htm Hope this helps??? -
Local topo maps, or google earth will reveal true North (or south). You can also look at the sun! The highest point of the sun durning the day will reveal true south. (Remember, not at clock noon, but solar noon. Just watch your sun for a few days around noon and you will see where it is. Or for a more esoteric way, find the sun rise/sun set locations on the solstice. Everywhere on the planet, the sun will rise due east and set due west on the solstice, revealing that south is 90 degrees off those angles. Or, get up early, mark the sunrise location (assuming flat ground), then mark the sunset location, due south is directly in between. (Simple GPS will tell you as well)
Lots of ways to skin the cat.
Tony -
I've always liked the Shadowless Stick method, or the Stick, Shadow, Duck method:
Use a stick, stuck in the ground , put a stack of pebbles (a duck) where the shadow is. Every 30 minutes, mark the shadow again, you will have a true E-W line, and can obtain N-S from that.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
or use a stick and do this at solar noon and the resulting shadow line is a north/south line. remember solar noon is in the exact center between sunrise and sunset times and these are often given by weather forecasters.
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
