Probably a dumb question
Can my PV charge controller, and the charger on my Tripp Lite inverter/charger charge the batteries simultaneously? I have an off grid, dual voltage system that requires simultaneous use of both generator provided 110 and batter provided 12v. During the day, typically, only the refrigerator is on 12v/110 inverter power, but occaisionally we will run the generator during the day for ac, when running the Trip lite inverter becomes a charger and would be sending current to the batteries along with the pv charge controller.
Is this okay?
    Re: Probably a dumb question
    Both chargers ( solar and 120VAC ) should monitor the battery state of charge, and adjust themsleves accordingly.
    If they don't, I guess I'll be hearing back from you after the weekend
  • System2
    System2 Posts: 6,290 admin
    thanks, that is what I thought too. I suppose I will find out!
