Do Solar cells vary in their response to different wavelengths, or color, of light?
Hi,
I am thinking of doing an experiment on solar panels. I need to know whether solar cells vary in their response to different wavelengths, or color, of light?
Thanks alot
  • Windsun
    Windsun Solar Expert Posts: 1,164 ✭✭
    Re: Do Solar cells vary in their response to different wavelengths, or color, of ligh
    http://www.solarnavigator.net/how_solar_cells_work.htm
    Found a spectral response curve for a typical silicon photo diode...
    However, if you are trying to make accurate measurements, you should pick a part where you can get the response curve specifications. The construction of of the detector and variations in design (based on requirements) can shift the curve quite a bit (plus some detectors may have filters so that they mimic the response of the human eye for use in those types of applications).
  • System2
    System2 Posts: 6,290 admin
    hi,
    Thanks alot guys. Admin that post was really good. I got a lot of knowledge about solar panels. Also BB thanks for the link. It's really going to be useful in my experiments. I can refer to it and check with my results.
    Thanks alot.
    Dilan
