need a 12v thermostat for vent fan..
notsobright
Solar Expert Posts: 247 ✭✭
hi everyone, does anyone know where I can find a 12vdc thermostat that will control a roof vent fan so that it will turn the fan on at 85 or so degrees (F) and then off at 80?
an adjustable one that is within this range would be great but I dont know where to look for one. internet searches havnt helped me much. I found a fantasticvent that has one but the company wont sell the thermostat seperately.
thanks
thanks
Re: need a 12v thermostat for vent fan..
If you could find an old, but still good wall thermostat for inside a house, you could probably place this in the attic, and if might work OK if the current drawn by the 12 volt(?) fan was not excessive -- I assume that you do not want to run the fan on AC.
The hysterisis (the difference between the ON temp and the OFF temp) is often not adjustable on older thermos, but may be worth a try if you can find an old thermo at a recycler, perhaps.
Tha attic fan thermostats WOULD be ideal, and you could probably find one as a service part for an existing attic fan, altho by now, some of those thermos may have solid state AC switching devices (like a Triac), and would not be suited to DC control.
Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
if going with vic's idea it may be better to have the thermostat activate a relay. -
Places like Graingers/McMasters and such have various basic thermostats.
Here are the HVAC T-stats. Note, that many are 120/240 VAC 10 amps or more--if your DC is not that high of current, you can probably use one of these just fine.
If your fan motor is inductive--you can add a snubbing diode on the power line to the fan:[FONT=Fixedsys] / +------/ :------+------ [fan motor + line] | ------ /\ [snubbing diode] / \ ---- | [ground][/FONT]
The diode provides current just as the switch opens to the inductive windings of the motor to protect the switch from arcing.
I think I have an old one of those but I just assumed it wouldnt operate @12vdc.
I need it for my RV so I wonder if it will work correctly while mounted horizontal or other than vertical? its just a spring right?
it doesnt have to have seprate on and off settings really. I'll see if I can find it now.
thanks
edit: Im using a 4" muffin fan from a computer. definately low amp draw. relay probably not needed but I think a diode might be.
thanks again -
No diode will be needed, also, you can use any thermostat for that type /size of fan. Most of them draw less than 1 amp. -
Heres one: http://www.vellemanusa.com/us/enu/product/view/?id=523193 -
A line voltage open on rise, or open on fall tsat will work just fine, (assuming small DC current. As Bill suggests, look at Grainger.
Tony -
Sorry, I intended to put a link in for Grainger's HVAC Thermostats.
And here is McMaster-Carr
By the way, Grainger's only sells to businesses (and their prices are not cheap). They don't sell to retail customers (as far as I know). I don't know about McMaster-Carr.
Re: need a 12v thermostat for vent fan..Sorry, I intended to put a link in for Grainger's HVAC Thermostats.
-BillPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 218 Forum & Website
- 126 Solar Forum News and Announcements
- 184 Solar Information links & sources, event announcements
- 884 Solar Product Reviews & Opinions
- 254 Solar Skeptics, Hype, & Scams Corner
- 22.3K Solar Electric Power, Wind Power & Balance of System
- 2K Advanced Solar Electric Technical Forum
- 427 Caravan, Recreational Vehicle, and Marine Power Systems
- 646 Solar Water Pumping
- 813 Wind Power Generation
- 598 Discussion Forums/Café
- 297 In the Weeds--Member's Choice
- 72 Construction
- 105 Old Battery Tech Discussions
