Resetting Bulk and Float levels...
Photowhit
Solar Expert Posts: 6,003 ✭✭✭✭✭
Well I've installed a new/used charge controller, and everything works fine...
...except the Bulk charge level was set for 28.1v and the Float for 27.1. Read off the inverter and confirmed by an inexpensive meter. So I figured it was originally set up for AGM so I went in to reset and reading the "micro voltage?" I found it was correct for what should have been 28.8 and 27.5(or so). so I reset them by watching the Bulk and today the Float levels.
So the voltage at the "potentiometer?" doesn't match the instructions but the Bulk and float now come up to the correct level.
Is this common?
Is this common?
Re: Resetting Bulk and Float levels...Well I've installed a new/used charge controller, and everything works fine...
