Connecting two single phase solar inverter to one 3 phase bi directional meter
I have a system in which one 3KW single phase inverter and other 5 KW single inverter. How can i connect these 2 single phase loads to my one bidirectional meter
  • BB.BB. Posts: 27,887Super Moderators, Administrators admin
    I am not surei understand your application.
    If you have 3 phase power and two grid tied single phase AC inverters, technically, you just connect them up per code (single phase each) and you are good to go. The 3 phase meter will record your power correctly.
    In practice, 3 phase power is done differently by different utilities (Wye. Delta, open Delta, different voltages, regulations on phase imbalance, loss of phase, billing for gt solar, etc.).
    You are in India (I think), and i have no idea regarding your standards.
    Bill
  • PhotowhitPhotowhit Posts: 4,703Solar Expert ✭✭✭✭
    Are you off grid trying to measure your power usage with an old grid meter?
    Since they aren't synced, I would think only one at a time...
    edited October 1 #4
    I think this is GT inverters (single phase) in a business or home served by with 3 phase utility power.
    To save money with GT solar...
    Bill
    I should have looked where it was posted...
