16 Solarex MS120 Panels for free? Any good?
tauras911tauras911 Posts: 1Registered Users, Users Awaiting Email Confirmation
Hi,  A friend has offered me 16 Solarex MS120 panels for free.  Actually a family member left them on his property and he wants them gone, lol.  Anyways, I believe these panels where available around 2010 and are not longer offered.  I am really new to solar, but have been wanting to get into it and been looking for free equipment to get started.  Well, here is some.  Can you tell me whether it is worth it drive and hour and grab these... are these still viable.  What else would I need to get a solar setup going besides a ad/dc converter, solar regulator, and batteries?
total newb to solar, if you couldnt tell.
Thanks all!
  • mcgivormcgivor Posts: 2,203Solar Expert ✭✭✭✭✭
    Free is always a fair price, most panels last in excess of 25 years unless something abnormal occurs, starting with panels is not the ideal approach to design but for a learning experience the price is right. With regards to the other components needed, that would depend largely on intended use, most will need some means of controlling and storage, charge controller/battery.
  • littleharbor2littleharbor2 Posts: 1,027Solar Expert ✭✭✭✭
    Those sx 120's are likely older than 2010 vintage. Solarex  sold out to BP, I believe, in the early 2000's. Those are 24 volt nominal panels and if functional would be perfect for getting your feet wet with solar, off grid education. Being 24 volt panels your simplest approach would be with a relatively inexpensive PWM type charge controller and a 24 volt battery bank. If you want to go with a 12 volt system you will need to start with a somewhat more expensive MPPT controller.
     The normal approach would be to identify your loads and build from there. I recommend you do a lot of reading here on this site and others to educate yourself in regards to what is required in designing and assembling an off grid system. It wouldn't hurt to start with a couple panels, controller and  small battery bank. to get a feel for and power a few lights and charging devices but don't start buying any larger more expensive equipment till you have gotten better informed and understand how to design a balanced system fit for your eventual loads.
