Renogy Rover 40A CC Mppt error code
Fabian
Registered Users Posts: 134 ✭✭
I have a Renogy Rover Mppt 40A charge controller which is displaying an error code: ACr
It is not working. Display turns on, but just displays "ACr." Does not respond to buttons. Does not appear to charge batteries.
What can I do to repair the CC or remove this error code?
what does this error code means?
Do a reboot, disconnecting solar first, then battery, Walt 5 minutes connect battery, wait for the boot process to complete, if everything seems normal connect PV. Just a suggestion, electronics sometimes get caught in a loop, a reboot is the first thing I would do.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 232 Forum & Website
- 620 Discussion Forums/Café
