Trace DR 2424 inverter fix.
I recently picked up a Trace DR 2424 inverter. When I removed the housing to access the interior of the inverter I noticed the tiny button that controls the power, on/off function had broken off at its base, which is an equally tiny pot or whatever you would call it. I'm really surprised to find a Trace product with such a miniscule component controlling a vital function. Sorry I didn't get pictures of it while I had it opened up. If you are looking at the face of the inverter it is the first tiny dot to the right of the square jack on the far left of the controls. I was hoping that someone out there has dealt with this problem and can point me in the right direction. heres a page from the manual which is clearer than my photo, http://powertool.manualsonline.com/manuals/mfg/xantrex_technology/dr2424.html?p=58
2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 700 ah @24 volt AGM battery bank. Plenty of Baja Sea of Cortez sunshine.
0
If not, there has to be some local place that could replace the contacter.
If you can live with MSW you will be pleased with the Trace.
Mine has performed flawlessly for 24 seasons.
Funny I thought about using a toothpick too as you suggested and he said that shaft has an electrical contact on it that electronically activates the switch and that a non conductive item like a toothpick wouldn't work.
BTW The button/shaft of this switch is about as thick as a pencil lead and the base is about 1/4" x 1/4", In other words its TINY
https://www.e-switch.com/system/asset/product_line/data_sheet/185/TL3301.pdf
https://www.ebay.com/itm/50Pcs-6x6x12mm-Panel-PCB-Momentary-Tactile-Tact-Push-Button-Switch-4Pin-E/222756480248?epid=9006335731&hash=item33dd5224f8:g:7EoAAOSwPe9Zr5kc
https://www.ebay.com/itm/140x-momentary-tactile-push-button-switch-micro-SMD-SMT-tact-switches-14-typeP-T/182917301023?_trksid=p2485497.m4902.l9144
