Solar and grid connection
fazilcvfazilcv Posts: 8Registered Users ✭✭
See this diagram, Grid and power from solar is connected as in diagram. If this connection is like this from where will be the load taken from the grid or from solar.
  • AguarancherAguarancher Posts: 271Solar Expert ✭✭✭
    edited November 2017 #2
    I believe your schematic is mislabeled. PV Service disconnect should read Inverter Service disconnect. You are also missing the PV Input to the inverter, which in my opinion would make the schematic correct.
    I would also add that for a system as large as yours and the questions you are asking, you really should have an electrical engineer involved, This system is way too large for DIY.. in my opinion.
  • BB.BB. Posts: 27,776Super Moderators admin
    Do not use the above schematic for connecting a standard off grid capable AC inverter. You will have smoke and possibly fire from your, now trashed. AC inverter.
    Here is a wiring diagram with an AC OF grid inverter that contains its own transfer switch:
    http://www.outbackpower.com/downloads/documents/wiring_diagram/905-0020-01-00_REV_A.pdf
    And here is an example with an external (manual in this case) transfer switch:
    https://www.solar-electric.com/lib/wind-sun/MNTransfer-wiring1.pdf
