What is a volt fault.
codger47
Registered Users Posts: 9 ✭✭
Checked the monitor a few minutes ago. It showed no activity, with the message 'volt fault'. I rebooted the system, and it's fine now. I would like to know what the error means other than no output, reboot.
What if anything dose your manual say, perhaps overvoltage? You could always call on the 12 year old but you may have to start paying him.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
On the second last page of the manual there are 2 Volt faults, Bus and PV volt fault, was there no indication of which one it was?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
