Someone please stop me!
littleharbor2littleharbor2 Posts: 1,036Solar Expert ✭✭✭✭
I'd like to ask members of this forum a favor. If I ever begin to comment on every topic on the board, regardless of the value of my comments. If I ever seem to comment just for the sake of arguing, or starting an argument. If I ever begin to continually question others advice, second guess them or  flat out tell them they are wrong because in my mind my way is best. Please, please, somebody stop me because I find it very annoying and wouldn't want any of my respected fellow members here on this forum to have to put up with it. I can take a hint.
Thanks, Littleharbor2
  • Marc KurthMarc Kurth Posts: 446Solar Expert ✭✭✭✭
    edited July 2017 #2
    I knew I liked you, but now you have been elevated even further. I think that it's time for me to move on.
    I always have more questions than answers. That's the nature of life.
  • SolraySolray Posts: 246Registered Users ✭✭
    edited July 2017 #3
    You just made my point for me.
    Hopefully Bill will leave this thread active long enough for good folks to POLITELY explain what the problem is. That might help you.
    Well, now I see that you changed your post as you like to do.
    You posted that you would be "Happy to help me leave" - then you pulled your classic 180 degree turn.
    I will politely back out of this conversation and let you play your games - in a place that most of do take seriously.
    Marc
  • mcgivormcgivor Posts: 2,226Solar Expert ✭✭✭✭✭
    The virus has mutated, I'm pretty sure of that, I've used all the antibiotics at my disposal, perhaps someone else has some available, they would need to be pretty strong as the mutation is not responding to the common  over the counter types.
  • nickdearing88nickdearing88 Posts: 96Registered Users ✭✭✭
    Honesty, while difficult, it's best just to ignore them (or the specific post). This behavior is usually seeking attention, be it positive or negative.
    That being said, I have so enjoyed my time (many, many hours) spent on this forum since I've joined. I've learned so much and discovered there's so much more to learn! I appreciate all the "useful" posts, not so much the ones described above.
    Current test system: 4-100w Renogy panels mono/poly, 1 string of 4 panels in series - 24v 100Ah AGM Battleborn LiFePO4 batteries - Morningstar MPPT40 CC - 1500W Samlex PSW inverter
  • mmaritzmmaritz Posts: 15Registered Users ✭✭
    That's my challenge as well Marc.  I have searched far and wide for an excellent forum for Solar specifically and this is the best I have found.  By far.  It covers all issues and forumites are largely very well informed and knowledgeable.  Took me time to get here and I don't want to move on :)
    Limited system to supply lights, alarm, internet and TV backup.
    Axpert (PIP4048) 5kv 48V, 8x102ah Excis Batteries (2xHA02 Battery Balancer), PV 1800w NE facing (2x 300W Renesola, 4x 310W Yingli & 480W W facing Microcare 40A (2x 240W ElChepo), Victron BMV 702, 6 string combiner box with PV isolator switch, subDB for inverter supplied power.
    SolarWEB Software for management, automated switch over and monitoring, pushing data to EMONCMS and PVOutput.org (Aloe Ridge Farm).
    Weather from personal weather station using Cumulus Software.
