design steps for installing solar panel
surlikar
surlikar Registered Users Posts: 1
Hello,
I am designing a solar system I need some help with design steps.
the site has two 120/240 v service panels , 600 Amps each.
how should i determine which panels , inverters and optimizers to use
what calculations are required for it?
    What are the desired system requirements?  Most households have a single 200a panel
    BB. Super Moderators, Administrators Posts: 33,714 admin
    You also need to talk with your utility/research what they allow for GT Solar connections. Typically, more than 10,000 Watts of solar panels moves you into "commercial" power--Which can have a whole different set of requirements and rate plans.
