Basic pwv charge controller recommendations please
First time solar user, starting to build a system for my camper. I need a solid reliable charge controller to go with my 100 watt panel. I've read tons of reviews on controllers(on Amazon, net, etc) and seems like all have some negative reviews a lot of which are dead on arrival, somme more than others, is this common throughout the industry? Since this is my first venture in solar I don't want to buy high quality mppt (probably will step up to it later) but will spend whats necessary for a good or even best 30 amp pwv. Recommendations and info appreciated.
thanks, Brian
  • vtmapsvtmaps Posts: 3,738Solar Expert ✭✭✭✭
    calstar wrote: »
    Welcome to the forum,
    I think you want a PWM controller (not a pwv). The Midnite Brat and the Morningstar units have excellent reputations. Take a look at what our host sells, they don't sell junk.
    --vtMaps
  • calstarcalstar Posts: 3Registered Users
    vtmaps wrote: »
    --vtMaps
    Yep, and thanks for the info, I'll check the hosts. Brian
  • mtdocmtdoc Posts: 600Solar Expert
    If you just need a CC for one 100W panel then you don't need a 30A CC. For one 100W panel, I would reccomend this Stecca controller. It costs a bit more but includes an LCD that gives you info on your PV output, charging amps, voltage and state of charge.
    If you really need 30A capability because of planned expansion then I agree with vtmaps that the Morningstar PWM controllers or the Midnite Brat would be good choices
