Solar thermal panels to heat garage floor
New to the board so I may be in the wrong pew. I have built a 620 sq. ft. garage with 220 feet of 1/2 inch pex pipe at the bottom of a 4 inch concrete floor. I would like to use about 40 square feet of solar panels to heat antifreeze and pump it through the pex tubing. I'm puzzled about the pump size and also whether it would be possible to just cascade the fluid over the metal plate absorber without using tubing? If tubing is necessary what size and how much is about right per square foot of collector? Any comments or suggestions would be appreciated or point me to a book which has some detailed guidance. Thanks, jabber.
Re: Solar thermal panels to heat garage floor
Couple of questions
Where are you located and do you have an estimate of the heating load in BTUs required to heat the building. Only then can you figure out, in your climate if your collector sizing is enough (or too much)
I have no idea about cascading the coolant, my own intuition (and I am no expert) is that I would rather see it in tubing.
As for pumps, go to WWW.Grainger.com and look for low flow circ pumps, (or NAWS) for that matter. Be cautious however, some cast iron impeller pumps don't like pex tubing, or more correctly, the pex tubing doesn't like the cast iron. Some thing is in the iron that has a detrimental effect on the pex. There are pumps available for pex, and there is hydronic pex that is Ok with cast iron. (I think!)
Other than that it is pretty simple to do. You might want consider adding a storage tank of some sort to collect during the day, and give back at night. In that case you might need two pumps and two sets of aquastats.
Tony -
Thanks for the quick reply. I am in northeastern Montana. My hope is that a solar system would ease the heat bill and add almost comfort at 30 degrees. When it is 20 below I'll almost certainly stay in the house. The 40 feet of collector is based on the excess thermopane windows I have and the fact that I want to tuck them a bit under the eave to keep them away from the June-August sun. -
You want to keep it in tubing - in fact, you're probably better off to buy absorber plates with tubing, which will also have the fancy coatings that make them work better.
How many loops is your 1/2" pex in? if it's just one loop, that is a fair amount of dynamic head, IIRC - I went with larger diameter tubing, but if the floor is cast, you work with what you have.
While I understand the desire to recycle the leftover thermopane, polycarbonate greenhouse glazing makes a better covering for home-made panels. Commercial panels will work better than home-made panels, on the whole. Given the cost of the circulator they might make sense. But anything is better than nothing.
Basic idea would be to connect your tubing to collector tubing, with a solar circulating pump run by a solar panel when the sun shines (simplest) or a 110VAC circulator which then requires a brain (controller) to know when to run. There also needs to be an expansion tank, a T&P relief valve, and an air removal valve. That's the basics. Something to keep it from cooking in the summer would be the next (a valved loop that ran to fin-tube in the cupola on top of the garage would be a good one - increase ventilation with the heat - you can also shade the panels for the summer). Or perhaps it runs to a hottub built out of a spare watering trough for the summer?
The folks at http://www.radiantcompany.com/ Should be able to help you sort out an appropriate circulator. They will also be able to advise you on a good ratio of collector area to floor, though that depends hugely on insulation amount and placement - I hope you used some...
Cheesiest (that's not good, but it's easy-cheesy) home-built collector - build a hot air panel and run fintube though the top of it. By the time you've built a good homebuilt one, you would usually have done better to buy one, IME. -
Patio door glass comes in standard tempered sizes of 28x76" or 34x76" These can be had free or almost free from almost any glass shop. A single glazing of tempered patio door glass would allow you to build modules of almost any size. I agree that premade absorber plates would be the easiest, but a simple manifold or loop of copper tubing, placed on top of a piece of scrap steel, on top of 2" of thermax insulation enclosed in a wooden box covered with a number of patio door glazing units would be a pretty easy DIY project. A simple Grunfos pump and a simple aqua stat, T&P valve, air bleed valve and away you go.
I built a domestic hot water system much like that, but with no glycol,, cost ~300 when all was said and done,,, had the copper and the steel however.
As for over heating in the summer,,, make some simple summer shades. If it doesn't get sun,, it won't get warm. You can also consider the over hang of the roof to shade it in the summer, as well as plantings etc.
Tony -
See an example here:
Solar Shed
500 gal storage @ 180F
http://www.builditsolar.com/Projects/SpaceHeating/SolarShed/solarshed.htm
http://tinyurl.com/6hypytPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Just make sure the pex has the oxogen barrier then you can use any pump and for the summer a brazed plate heater could help you get domestic hot water.
Ken -
There is pex with oxygen barrier, which can be used with cast iron pumps and other components. There is pex without oxygen barrier, which should only be used with bronze, plastic or stainless pumps. It's a rust issue. Whatever he's got in the floor, the rest of the system will have to match.
Personally, having seen the inside of a number of "sealed" cast iron systems after a few years of operation, I try to avoid cast iron pumps, pipe, etc. anyway. The "in theory limited" rust is often enough to eventually cause problems, but that's practice & experience rather than theory speaking. Cast iron is certainly cheaper, at the start. In the long run bronze & copper may be cheaper, in practice.
- 224 Forum & Website
- 132 Solar Forum News and Announcements
- 196 Solar Information links & sources, event announcements
- 815 Wind Power Generation
- 617 Discussion Forums/Café
- 310 In the Weeds--Member's Choice
