GroundTrac 5-foot height limit
aj164
Solar Expert Posts: 122 ✭✭✭
I'm installing a ground-mount system, and I plan on using GroundTrac hardware from Professional Solar Products. The instructions say to use 1-1/2" pipe, and that no support post can be longer than 5' from ground level. If I do this (with a 30-deg angle array), the bottom of the array ends up less than 1' off of the ground. I would like to see it at least 2' at the lowest point, but that means violating the 5' post length.
I expect the problem is bending forces on the posts due to wind. So it seems if I increased the size of the taller posts to 2" (with a transition near the top back to 1-1/2"), this issue would be solved. Also, the soil here is very heavy clay, so it is unlikely that we're risking the footings moving on us.
Anyone have experience with ground mount? Thanks - AJB
Re: GroundTrac 5-foot height limit
Well, you could make the footing taller - keeping the post to 5' unspliced, but they reference to ground.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
mike has an excellent idea going upward with the concrete, but you may need to widen the area for the base over that which would've normally been there for the concrete to better stabilize the increase in side forces from the wind. -
I don't know if the specs call for it, but you can FILL the pipe with concrete as you set it in the footing. A poured core with 1 1/2" galvanized pipe, with a strand of 1/2 re-bar in it would, IMHO make up for the additional foot. You could also extend your footing 1 foot using a ~12" diameter sono-tube. You could get real creative and do a tapering footing, or a wedding cake footing with different sized sono-tubes.
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
