How to include bypass diode in solar module modelling
hi,
I am working on mismatch losses in solar strings. I need to put bypass diode across 36 cells out of 72 cell module. i.e. 2 bypass diode across a module. I am using Mathcad for modelling.
please suggest me the ideas for the same.
Binod
Binod
Re: How to include bypass diode in solar module modellingbpkoirala2 wrote: »hi,
Binod
Why use 2, when 1 will do ?
Are you talking diodes in series to achieve a voltage spec, or in parallel to pass some amount of current ? Diode or Schottky diode? (different Vf spec)
Can you post a quick sketch of what the heck you are thinking of, it makes no sense to just add diodes. What's the Mfg/Brand/Model of panel - it may already have diodes. Your Charge Controller may already provide this function.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
thank you for reply.
I dont have solar panel for the time being. I am doing simulation only.
if u still can suggest, please..
thanks
binod
