replacing asphalt shingle roof vs applying sealent coating
westbranch said:Is the underlay self-healing?
Just inquire at a roofing place that does commercial installs, ask for Peel-and-Stick type, common as dirt.
One of the top brands is Soprema, ask for the Blue Elephant -
The ice shield is sticky and glues it self to the wood serface .
Some you can peel up but some becomes a real sticky mess.
Not only can you not peel the ice shield off the wood but it's a real job to get the shingles off also .
Some times we end up banging the ply wood off and replacing it .
In my area GP had a bad run of ply wood in the 70 and the stuff just rips up when you remove the shingles.
Gaf weather watch is good stuff .
Not to sticky , it has a granulate surface so you could walk on it .
I think it's 55 bucks for 200 feet .
Grace makes the best Products but it is more then double the price.
i used ice and water shield on the entire roof because I have 1x8 rough saw decking and did not want to get nail leaks
because of expansion and contraction of lumber , plus I am in a hi wind area .
And yes the nail holes don't leak.
I really wanted a Metal roof but it just cost too much money .
My guys shot my roof on for food and beer .
2 guys 2 days sun up to sun down 6000 plus feet .
My son and I layed the plywood and ice shield and my roofers just shot shingles.
Steal would of taken weeks that I did not have.Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
- 654 Solar Water Pumping
- 620 Discussion Forums/Café
