DP 60amp breaker in place of SP?
                    tripster
                    Registered Users Posts: 14 ✭
                    My Xantrex PS2524 specifies the use of 60 amp breaker to feed the ac in on the inverter.  The inverter is capable of 50 amp pass through.  I am having a hard time finding a 60 amp single pole ac breaker.  Can one side of a douple pole 60 amp be used?
Thanks,
      Thanks,
            Re: DP 60amp breaker in place of SP?
 Should be OK.
 HTH,
 Jim / crewzer
 Thank you. I shall move forward with the install!!
- 232 Forum & Website
- 620 Discussion Forums/Café
