Link 10 Voltage Display
fatheadlfatheadl Posts: 31Solar Expert ✭✭
Hi All,
I just installed a new Xantrex link 10. The voltage display keeps fluctuating +/- 0.5 volts of the battery voltage. Is this normal?.
Thanks in advanced
fatheadl
  • crewzercrewzer Posts: 1,832Registered Users, Solar Expert ✭✭✭✭
    Re: Link 10 Voltage Display
    No, that's generally not normal. Exceptions could include rapid changes in charge/discharge current to/from a small battery bank. My Link 10's V display is fairly steady, and it changes in 0.1 V increments.
    Some suggestions:
    1) Make sure the shunt sense wire pair from the shunt to the meter is twisted together to help minimize noise pickup by this very sensitive circuit.
    2) Keep the shunt sense wire pair away from electrical noise sources.
    3) Double check all of the meter wiring and connections per the instructions.
    4) Check the manual's troubleshooting guide.
    HTH,
    Jim / crewzer
  • fatheadlfatheadl Posts: 31Solar Expert ✭✭
    Hi Jim,
    The 'Amps' display is steady, it's only the 'Volts' display. The battery bank is 12v
    Thanks in advanced
    fatheadl
  • rplarryrplarry Posts: 203Solar Expert ✭✭✭✭✭
    Just checked mine and it bounces around by 5/100 (.05) of a volt. Half a volt would not be normal.
    larry
    Hi All,
    My mistake +/- .05, so i guess that this is normal then.
    Thanks for the replies.
    fatheadl
