Different panels, one controller?
bumper
Registered Users Posts: 14 ✭
Question, example can you use three different voltage panels running into one controllers. Example
125 watt18.4 vmp
205 watt 27.9 vmp
260 watt 34.8 vmp
Would these be ok?
:p
125 watt18.4 vmp
205 watt 27.9 vmp
260 watt 34.8 vmp
Would these be ok?
:p
Re: Different panels, one controller?Question, example can you use three different voltage panels running into one controllers. Example
125 watt18.4 vmp
205 watt 27.9 vmp
260 watt 34.8 vmp
Would these be ok?
:p
No.
You can not mix panels of that different Vmp in parallel.
If you were to hook those up to one controller on a 12 Volt system you'd be losing about 47% of the 260 Watt panel and about 34% of the 205 Watt panel.
It's difficult to get dissimilar panels to function on the same controller. The rule of thumb is: no more than 10% difference in Vmp for parallel connections and no more than 10% difference in Imp for serial connections. 5% is better. The greater the difference, the more power you throw away. -
Re: Different panels, one controller?Cariboocoot wrote: »No.
If it's any help, the Kyocera 135 has a Vmp of 17.7 which would be close enough to the 125 Watt panel's 18.4 Vmp to work. They can be had new for less than $350 and are small enough to ship UPS. -
Re: Different panels, one controller?Cariboocoot wrote: »If it's any help, the Kyocera 135 has a Vmp of 17.7 which would be close enough to the 125 Watt panel's 18.4 Vmp to work. They can be had new for less than $350 and are small enough to ship UPS.
toss the 125w, and you will get more power from the other 2, than with all 3 ! IF you use a MPPT controller.
125 watt18.4 vmp
205 watt 27.9 vmp
260 watt 34.8 vmpPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Different panels, one controller?toss the 125w, and you will get more power from the other 2, than with all 3 ! IF you use a MPPT controller.
125 watt18.4 vmp
205 watt 27.9 vmp
260 watt 34.8 vmp -
Re: Different panels, one controller?I am running a tristar ts-45 controller ,just adding on as I can afford
BAD IDEA
What's your system/battery voltage ? 12V i'd guess. when you get into panels over 19V, you are seriously wasting their power, unless you have MPPT controller to downconvert the voltage to battery voltage.
You need to either exchange the HV panels, or the controller, or get a new budgetPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
- 626 Discussion Forums/Café
