XWPro "Active Power Limit (Charge)" No Documented Modbus Key/Value ?? (For use in script programs)
JustJoe
Registered Users Posts: 2 ✭
Grid tied solar system
2x XW-Pro v2.04.00 Conext Gateway v1.18
AC coupled to 2x SMA SunnyBoy Solar panel inverters
7x SimpliPhi 3.8kW batteries
Have had a 3 yr tolerate/hate relationship with Schneider XWP + CGW. My neighbor got roped into buying all this hardware, but only later realized how hard it was to keep from just sending super cheap power to the pg&e grid (too late for netzero). They were really tight on money due to health issues, so I wrote a bunch of (lua) scripts to do the daily monitoring & control.
I knew going in, the sunny 9 months of the year would WORK GREAT. Originally I was even running a 5sec network Modbus loop that would only charge batteries based on excess solar power after in-house usage. Was happy to do a major code rewrite when the last XWP v2.04 + CGW v1.18 code nicely took over that task.
But now for the 3 months of (cloudy) winter... To keep grid power from being used during Bulk/Absorption charging, the system normally (spring-fall) runs with:
Devices / Config / Power Control Settings /
AC1 Grid/Generator Active Power Limit (Charge) = 3 W
But there just isn't enough solar power in any particularly dark day. Manually changing this value (eg. 3000W) to supplement with some grid power works fine ... But I don't have the time to check the weather and adjust it every day. My control scripts could easily be doing this ...
BUT DAMN IT ...
that setting has NOOO documented Modbus key/value I can find in the Schneider Modbus x-ref pdf which could be sent from my script program.
...AAARRRGGG !!!
I know that some of you guys have tried hacking Xanbus ... I am currently trying to see if I can get wget or curl to issue http POST commands in place of Modbus ... But I keep running into not being able to automate login credentials.
Being a masochist, I actually have a XWP + InsightHome on order with NAZ, so I might even be able to try serial wireshark digging...
But otherwise, I think schneider lost their good programmers, (we never even got the v2.10.00 that was promised), otherwise this would have been a request for them to correct a Modbus oversight.
Heeeelp, Suuuggestions, Pleeeease ?
BUT DAMN IT ...
...AAARRRGGG !!!
write this in an easier way to understand is my suggestion. Not that I can help you as I pay someone for this, but it might help to re-write for others."we go where power lines don't" Sierra Nevada mountain area
E-mail offgridsolar@sti.net -
Dave Angelini said:write this in an easier way to understand is my suggestion. Not that I can help you as I pay someone for this, but it might help to re-write for others.
But therein lies a possible problem... Schneider seems to have kicked their support out to The Philippines last summer. Do you know if they even have any real programming support contacts left for XW-Pro? Because if no, that leaves me needing ideas on how to hack to the xanbus side of the InsightHome.
- 222 Forum & Website
- 130 Solar Forum News and Announcements
- 192 Solar Information links & sources, event announcements
- 888 Solar Product Reviews & Opinions
- 254 Solar Skeptics, Hype, & Scams Corner
- 2K Advanced Solar Electric Technical Forum
- 425 Caravan, Recreational Vehicle, and Marine Power Systems
- 651 Solar Water Pumping
- 815 Wind Power Generation
- 611 Discussion Forums/Café
- 304 In the Weeds--Member's Choice
