GTK-002-Enphase kit for garden use
rrbv
Registered Users Posts: 16 ✭✭
Looking at the enphase grid tied solar kit two with 2600 watts of power from 8 ea 325 watt panels. Sounds like a great way to go, each panel has a micro inverter on it which should allow minor pointing dispersion due to mounting on top of my 5 ea garden beds with a structure which lifts the panels about 6' above the garden beds. The hope is that some shading will help the garden in southern NM, where the sun is hot and mostly there! My intent is to simply tie the power into my 1 1/2 hp well supply which is nearby at it's breaker. Any comments?
I
t depends on the buss bars at your well supply panel if that was what you were looking for a comment about? I presume you will be using a circuit breaker correctly sized for the Enphase circuit.
8 kW Enphase micros AC coupled to a SolArk 12K
- 225 Forum & Website
- 133 Solar Forum News and Announcements
- 197 Solar Information links & sources, event announcements
- 815 Wind Power Generation
- 617 Discussion Forums/Café
- 310 In the Weeds--Member's Choice
