Verifying panel performance before installation
dale
Solar Expert Posts: 29 ✭
Does anyone have any good suggestions on how to test panel performance prior to installation? In particular, I'd like to determine how identify dead cells.
I'd been thinking of building a small platform at the optimal angle for my region (30 degrees). Variable transient conditions, like clouds, make it more difficult to localize minor variations. Anyone know of any industry insider tools that simplify this?
Re: Verifying panel performance before installation
Three basic tests to see if panels are, roughly, OK...- Voc--open circuit voltage test. Just throw the panel in full sun and measure voltage
- Isc--short circuit current test. Set your DVM to 10 amp full scale and short across the panel output (it is OK to short the panels). Put panel in full sun and measure current (which will pretty much be porportional to the strength of the sun light). You can compare with another panel--if you have one.
- Properly connect your panel to a 12 volt car battery and measure current output in full sun.
#3 will find the few bad panels that have failed in certain ways that 1&2 may not.
If you are looking for panels that are outside the spec. range (10-20% out)--that is much more difficult without a pyrometer and specialized lighting.
If you do tests #2 and/or #3 with a known good panel and immediately flip over to the DUT (device under test--or use a second DVM)--you should be able to scale for variable solar output and find a "weak" panel. Remember, Vmp and Voc are temperature dependent--so you need to have both panels at the same temperature for accurate measurements (with better than 5-10% accuracy).
Also--if you have some need to test a lot of panels--I would be tempted to use a pair of small MPPT controllers to compare Ref/DUT panels into a known load (battery with load or something similar). Those would do a very good job of giving you accurate Vmp/Imp for yoru panels--but probably way overkill for the average person.
#3 may be difficult to determine if the battery is in various stages of charge as it stands to reason a fully charged battery will not allow as much current flow as one that is half depleted.
- 232 Forum & Website
